You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.2 (2238) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-12 10:38 | IP: IP Logged
pypardo:
The project list was stored in the registry !
And it seems that one of the project has a name that locks the mru list.
After clearing my projzect list in registry, everything to be ok.
Best regardssmiling smiley
It isn't true. In the Windows registry is MRU list from Windows standard Open/Save dialogs. This list has no relationship to PSPad. This is Windows thing, PSPad doesn't write it, PSPad doesn't read it. Windows Explorer do it automatically.
There can be a problem if your project name contains square brackets. Because PSPad uses INI files, item in square bracket means new section in ini file.
#22 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Jon | Date: 2006-10-12 10:46 | IP: IP Logged
> Works perfectly for me
It works here as well, as long as I have not activated the tool panel. Afterwards, "Next Window" and "Previous Window" (the menu commands under "Window") *only* change tabs in the tool panel. Ctrl-Tab works correctly.
> and I haven't changed anything since the previous build.
Neither have I. If I install 2238, I see this problem; if I go back to 2237, it goes away. If I switch again to 2238, it reappears.
Easy as that.
#23 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Lolo | Date: 2006-10-12 10:57 | IP: IP Logged
I can confirm the problem reported by Jon.
#24 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pypardo | Date: 2006-10-12 12:13 | IP: IP Logged
It's ok I fix my problem with project list.
In fact, my project list was stored in recent.ini file but under %ApplicationData% and not under pspad folder.
Now everything it's ok.
Best regards and thanks for support smoking smiley
#25 Re: PSPad unicode 4.5.2 (2238) English
Posted by: mathiasm | Date: 2006-10-13 12:22 | IP: IP Logged
Hi
Bug that exists since 4.5.0, but i was too lazy to mention:
If you double-click a file in Explorer and it opens in PSPad, PSPad will not add it to the MRU, and it should IMO.
Thanks
#26 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-13 12:48 | IP: IP Logged
mathiasm:
Hi
Thanks
PSPad adds file to MRU when you close it, not when you open it.
