You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2238) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-10 20:07 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.2 (2237)
News
I am able to recieve donation via PayPal
new icon set Gnome (MrSpok) - Ximian set replacing
you can handle wih Ctrl+Tab any tab based controls (LOG, ASCII chart, project panel)
you can cycle editor, LOG adn project panel with Alt+L
new variable %ProjectDir% returns project file path
added history for the Goto Line Hex editor dialog
Brazilian-Portuguese localization (Ericson L. Silva)
SQL code explorer modifications for MySQL
added keywords for PL/SQL (Oracle)
added AutoIt and AutoMOD Code explorer
search for current word (Shift+Ctrl+Up/Down) works in LOG window too
Corrections
Save block as - missing confirmation if file already exists
corrected FileZilla FTP account import
Open more file from Send to
PHP and Pascal Code explorer
cursor placement if no uccurence found
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
#2 Re: PSPad unicode 4.5.2 (2238) English
Posted by: MrSpock | Date: 2006-10-10 23:12 | IP: IP Logged
Eeeek! yawning smiley What happened to the colors? Jan, pleease! If you must have a 256 color version of the gnome toolbar , please choose this one (37KB). Yours has green folder icons, it looks dreadful. No insult intended, but it is really a pain to look at! winking smiley
Well, this being said -- thanks again. Your hard work is much appreciated.
#3 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-11 04:49 | IP: IP Logged
I don't need 256 colors, but users has then problems with remote access winking smiley
OK, I will include your full text color icon set
#4 Re: PSPad unicode 4.5.2 (2238) English
Posted by: naputtelija | Date: 2006-10-11 06:02 | IP: IP Logged
Which AutoIt version Code explorer does support, is it version 2 only? It does not work with current AutoIt (v. 3 has been out since feb 2004). It shows function calls only, not functions.
From AutoIt help:
Func...Return...EndFunc
Defines a user-defined function that takes zero or more arguments and optionally returns a result.
Func functioname ( [Const] [ByRef] $param1, ..., [Const] [ByRef] $paramN, $optionalpar1 = value, ...)
[Return [value]]
EndFunc
#5 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-11 06:24 | IP: IP Logged
I don't know AutoIt. I asked for description, source and I make code explorer as I get informations.
I really don't have enough time to study all languages, syntaxes...
If you are not satisfied with existing code explorer, send me some source samles with description, I will modify it.
#6 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Tonda | Date: 2006-10-11 07:21 | IP: IP Logged
Thanks for the SendTo-Fix!
Regarding AutoIt:
The AutoIt Team already provides syntax files for various editors. When you install AutoIt (http://www.autoitscript.com/autoit3/downloads.php) you can find them in AutoIt\Extras\Editors\PSPad.
HTH,
Tonda
#7 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-11 08:09 | IP: IP Logged
I don't need AutoIt syntax file. I need some source code with description what should be in the Code explorer
#8 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Lolo | Date: 2006-10-11 10:09 | IP: IP Logged
Thanks for this new release.
Unfortunately, we can see the return of an old bug already seen several times before.
Here is the way to reproduce it:
Fist of all, you should create two files named "Test 1.txt" and "Test 2.txt" for example in a folder with spaces inside its name like "Test - PSPad"
- Open one file in PSPad
- Now, select these two files and open them with the context menu
You should something like this:
I hope you could correct it quickly.
Thanks and have a nice day.
#9 Re: PSPad unicode 4.5.2 (2238) English
Posted by: pspad | Date: 2006-10-11 10:54 | IP: IP Logged
I am sorry for it. There are problms with Windows behaviour if you run files y the different ways and you need work with switches...
#10 Re: PSPad unicode 4.5.2 (2238) English
Posted by: Lolo | Date: 2006-10-11 12:37 | IP: IP Logged
I don't understand what you told me.
But, the problem I have reported does not exist in the build 2237.
Moreover, if you select the 2 files and press enter to open them, it works perfectly while it does not work if you try to open them with the contextual menu.
You already correct this problem by the past so I suppose you can do it again winking smiley
