You are here: PSPad forum > Developer forum - new builds > Re: Log file unreadable
Goto Page: Previous1 2 3 4 5 6
#51 Re: PSPad unicode 4.5.2 (2231) English
Posted by: vincevg2 | Date: 2006-08-25 09:15 | IP: IP Logged
I right click on the name and choose rename (Renommer F2) in context menu (see image). And nothing happen.
Best regard
Edited 1 time(s). Last edit at 2006-08-25 09:17 by vincevg2.
#52 Re: PSPad unicode 4.5.2 (2231) English
Posted by: wayshore | Date: 2006-08-25 13:26 | IP: IP Logged
I have to confirm this bug. I also can't rename folder-names
in the project-tree.
i didn't update since version 4.5.2.2223, but now got
an error-message every time when opening php-templates
and ONLY when opening php-templates)
this problem is gone with the new version 2231, but
now I'm encountering this rename-problem!
I tested other versions and found, that it appears since
2227.
#53 some demand
Posted by: vincevg2 | Date: 2006-08-25 14:35 | IP: IP Logged
hi,
is it possible :
- add more than 5 external application in a project ?
- Define a list of external application, they can be added directly in project ?
- add tool bar with project external application ?
- Run my personnal wizard when file new is invoked (and open the created file) ?
- add icon in personnal toolbar ?
- Choose the highlighter for one project ?
- Add the same 3 checkbox in external application than in compiler option ie: save, capture and hide ?
- Add + and - before loop or comment to reduce it (like scintilla, visual studio, eclipse ...) ?
- Add a menu with addmenuitem in the main menu (File, project, Edit ...) ?
Best regards
Edited 3 time(s). Last edit at 2006-08-25 15:13 by vincevg2.
#54 some demand .../...
Posted by: vincevg2 | Date: 2006-08-25 16:54 | IP: IP Logged
I've try to make previous demand with VBscript.
Is it possible to (with script) :
- Run log windows with output of my compiler (or other tool),
- Hide output windows,
- Parse the log.
Edited 1 time(s). Last edit at 2006-08-25 16:54 by vincevg2.
#55 Sorry it's ok
Posted by: vincevg2 | Date: 2006-08-25 17:26 | IP: IP Logged
grinning smileygrinning smileygrinning smiley
Edited 2 time(s). Last edit at 2006-08-25 17:31 by vincevg2.
#56 Re: some demand
Posted by: pspad | Date: 2006-08-25 18:33 | IP: IP Logged
vincevg2:
hi,
is it possible :
Best regards
No
#57 Re: some demand .../...
Posted by: pspad | Date: 2006-08-25 18:35 | IP: IP Logged
vincevg2:
- Parse the log.
How you want to run "log window" ? You can run program, not window winking smiley Show and Hide log window - send shortcut to program
You can parse log in script, you can do anything with log output.
#58 Re: some demand .../...
Posted by: vincevg2 | Date: 2006-08-26 11:42 | IP: IP Logged
Quote:
No
laconic winking smiley
You plan to do this ... ?
English, english sad smiley
#59 Re: Log file unreadable
Posted by: riechert | Date: 2006-10-17 20:20 | IP: IP Logged
moved to current thread
Edited 1 time(s). Last edit at 2006-10-17 20:22 by riechert.
