You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2227) English
#11 Re: PSPad unicode 4.5.2 (2227) English
Posted by: pspad | Date: 2006-07-03 16:46 | IP: IP Logged
PSPad sets Bold, Italic, ... for the char - it means the char is more wide then in the plain text (notepad)
#12 Re: PSPad unicode 4.5.2 (2227) English
Posted by: pspad | Date: 2006-07-03 17:04 | IP: IP Logged
llfbandit:
Is the current behaviour for the direct modification of the configuration is the intented one? (must cancel in the config panel after direct edit to validate...)
No, you have to confirm it.
#13 Re: PSPad unicode 4.5.2 (2227) English
Posted by: Neil Clough | Date: 2006-07-03 21:16 | IP: IP Logged
Quote:
Notice also the bottom status bar, which contains erroneous graphics. This is not new, I often get this (minor) bug since a while now.
I also get these.
Cheers,
Neil
#14 Re: PSPad unicode 4.5.2 (2227) English
Posted by: Jody | Date: 2006-07-03 22:25 | IP: IP Logged
I've notice on this version, 2227 and 2223 urls are highlighted but no longer open with alt+click.
Am I missing something?
Thanks,
Jody
Edited 1 time(s). Last edit at 2006-07-03 22:25 by Jody.
#15 Re: PSPad unicode 4.5.2 (2227) English
Posted by: MrSpock | Date: 2006-07-03 23:46 | IP: IP Logged
Thanks a lot for the new build. Looks like the find/auto-scroll issue is resolved now, as far as I can tell. smiling smiley
"Getting so much better all the time" (The Beatles)
#16 Re: PSPad unicode 4.5.2 (2227) English
Posted by: pspad | Date: 2006-07-04 06:40 | IP: IP Logged
Jody:
Yes. From the URL highlighting begin is Ctrl+Click used for the Open URL winking smiley
#17 Re: PSPad unicode 4.5.2 (2227) English
Posted by: rogerli | Date: 2006-07-04 07:55 | IP: IP Logged
When I print the files using PSPAD , just the header is showed up on the paper , there is no body , really strange , the printer is HP LaserJet 4250 PCL 6 , any clue?
#18 Re: PSPad unicode 4.5.2 (2227) English
Posted by: pspad | Date: 2006-07-04 08:22 | IP: IP Logged
rogerli:
Color settings in your editor? Did you try to switch off the colors in the preview ? Did you try to print it without preview ?
#19 Re: PSPad unicode 4.5.2 (2227) English
Posted by: guest | Date: 2006-07-04 15:00 | IP: IP Logged
unless I'm missing something, the command line passing of the line number in a file, is now broken and has been for several versions it seems.
Previously %PATH% /%LINE% passed from an external app (e.g. Search & Replace) would open the file and go directly to the line in question.
Now, PSPad opens a blank file (of the same name passed) and with a line feed (?) and line. e.g. opening foo.cpp to go to line 100, displays the following in PSPad
c:\bin\foo.cpp \100
#20 Re: PSPad unicode 4.5.2 (2227) English
Posted by: pspad | Date: 2006-07-04 16:05 | IP: IP Logged
Sorry, but you have to send
c:\bin\foo.cpp /100
not \100
