You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2221) English
#31 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Anonymous User | Date: 2006-06-08 07:07 | IP: IP Logged
I can confirm this misbehaviour
#32 Re: PSPad unicode 4.5.2 (2221) English
Posted by: naputtelija | Date: 2006-06-08 10:33 | IP: IP Logged
There is small problem with bracket highlighting and user highlighters. Highlighting does not work for the brackets in the first line of file. At the same time, ctrl+m works in first line, it's only highlightning that does not work.
I tried this with three different user highlighter. Internal highlighters are ok.
#33 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Jume | Date: 2006-06-08 18:07 | IP: IP Logged
dunno if it is intentional or not but here we go
html tags that do not get highlighted (matching words), i found these so far cause i needed to work with them, didn't tested all and any
h1-h6
font (i know, deprecated, lol, i really dont care about this one either)
object
body (i suposse it is not really needed in pure html, but in mixed content can be useful)
html (idem)
head (idem)
title
a
form
select
option
textarea
also, i noticed some flickering in the highlighting, not sure but it can be when there is too much content in the tag (e.g. a big table/div which has the contents of a whole full page)
#34 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-08 18:22 | IP: IP Logged
I don't thing it's usefull to highlight tag that are only one time in code - HTML, BODY, HEAD, TITLE, ...
If we will add new and new words, highlighting will be slower and slover.
We have to find some balanced state
#35 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Chris Pirillo | Date: 2006-06-09 00:43 | IP: IP Logged
Search and Replace seems to be completely broken. For example, I'll try to replace all "<" globally with "&lt;" - and it only detects the first couple. I have to run that query again, it detects one other... then run it again, detects another... etc.
#36 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-09 04:53 | IP: IP Logged
Chris Pirillo:
Yes, there are some problem.
Maube you can speed up your work with Tools/User highlighter and "Text to HTML safe form" definition
#37 Re: PSPad unicode 4.5.2 (2221) English
Posted by: n4cer | Date: 2006-06-09 15:47 | IP: IP Logged
Would be nice to be able to set the Font PSPad uses for Menu, Code Explorer, File Explorer, etc.
On my Laptop "Lucida Sans Typewriter 7pt" looks great for code and saves a lot of space on 1024x768 screen. So I wish I could set the rest to "Lucida Sans 7pt".
#38 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-09 16:36 | IP: IP Logged
n4cer:
You can do it by the modify Language file. On the start you can see commented font name
#39 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Bart | Date: 2006-06-10 08:33 | IP: IP Logged
Mhm, it seems that replace in files does not work, neither "All opened documents" nor "In Folder".
#40 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Bart | Date: 2006-06-10 08:36 | IP: IP Logged
...and I'm dreaming about extended replace for multiple line and text blocks like Homesite has:
podklady.interval.cz smiling smiley
