You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2221) English
#11 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pjj | Date: 2006-06-05 20:56 | IP: IP Logged
XHTML Multi works fine now; many thanks!
(I noticed some HTML tags got highlighted, too. It is a nice feature, and I suppose highlighting some more would also prove useful, eg. <li>, <dl>, <pre> etc.--since all of them may be multiline, <li> included--cf. sublists, ie. list inside a list.)
#12 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pspad | Date: 2006-06-05 21:02 | IP: IP Logged
pjj:
I don't want to highlight all pair tags. Users should select important pair tags only. E.g. <li> isn't good idea, because </li> isn't necessary sad smiley
#13 Re: PSPad unicode 4.5.2 (2221) English
Posted by: jgodfrey | Date: 2006-06-05 22:01 | IP: IP Logged
Wrapped searching appears to be broken in 2221/2222 when the matched term is not found within the first visible screen of text at the top of the document. To see the problem...
- Select a word that appears multiple times in a (largish) document
- Search "forward" by using Ctrl+Shift+DownArrow.
- Continue searching forward until the last occurrence of the word is found
Now, an additional Ctrl+Shift+DownArrow should wrap the search and start from the top again. If the search term is found within the first visible screen of text (at the top of the file), it is found and all works normally. If the term is not found in the first screen of text, no match is found. An additional Ctrl+Shift+DownArrow press in this case seems to skip the first occurrence of the term and start at the second occurrence.
Jeff
#14 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pjj | Date: 2006-06-05 22:05 | IP: IP Logged
In XHTML all tags should be closed, single tags included: <br />, <hr />, <meta /> etc. To let users choose which tags to highlight would be--as always--the best solution (low priority, though winking smiley)
#15 Re: PSPad unicode 4.5.2 (2222) English
Posted by: Ilya | Date: 2006-06-06 04:35 | IP: IP Logged
I have performed a small test and have found that (in TCL highlighter) the Brackets Matching doesn't work :
1. the second (right) bracket isn't highlighted
2. the first (left) bracket is highlighted by color of "LOG parser" (Program Settings...->Colors) - changing LOG Parser's color changes the left bracket's color.
#16 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pspad | Date: 2006-06-06 04:50 | IP: IP Logged
Ilya:
OK
#17 Re: PSPad unicode 4.5.2 (2222) English
Posted by: stefan gabos | Date: 2006-06-06 07:02 | IP: IP Logged
Oh yeah! I love the highlighting of HTML tags! But the man's got a point:
pjj:
I think it would be nice to be able to have a file where we can set which tags to be highlighted
#18 Re: PSPad unicode 4.5.2 (2222) English
Posted by: Vasik | Date: 2006-06-06 07:21 | IP: IP Logged
Can't download version 2222. :(
Bad arhive :(
#19 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pspad | Date: 2006-06-06 07:31 | IP: IP Logged
Vasik:
Bad arhive :(
Can't confirm. Problem is on your side. I downloaded it now and unpacked without any problem.
#20 PSPad unicode 4.5.2 (2222) English
Posted by: | Date: 2006-06-06 07:37 | IP: IP Logged
With builds 2221/2222: Cannot open file ****
This happen on any file, including default files.
On exit PSPad crashesh with error:
System Error. Code: 5.
Access is denied.
Exception class: EOSError
Exception address: 00412B52
Stack list, generated 06.6.2006 ã. 10:34:09
[00412B4D] SysUtils.RaiseLastOSError + $75
[00412B7B] SysUtils.Win32Check + $7
[00424DA6] Classes.THandleStream.SetSize + $1E
[00424927] Classes.TStream.SetSize64 + $B
[005AE027] uFileSetting.TFileSetting.OpenStream (Line 140, "uFileSetting.pas" + 36) + $4
Moderator: don't send error messages here.
I gues you don't read a PSPad changes above. There is mentioned to delete PSCache.BIN if problems with a file settings occurs. Do you did it ?
Edited 2 time(s). Last edit at 2006-06-06 08:13 by pspad.
