You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.2 (2221) English
Goto Page: Previous1 2 3 4 5
#41 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Mark Baines | Date: 2006-06-10 11:25 | IP: IP Logged
I can't select the last 2 lines using a left-click in left-hand number gutter.
#42 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Mark Baines | Date: 2006-06-10 11:32 | IP: IP Logged
When I left-click on the left gutter to select a line that wraps, I would have expected the whole line to be selected to the end of line marker (regardless of how many screen lines it takes up) rather than just the one screen line clicked on. Selecting a fragment of a line is pointless.
#43 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-10 11:46 | IP: IP Logged
Bart:
Mhm, it seems that replace in files does not work, neither "All opened documents" nor "In Folder".
Take an attetion to the file extension list in the file replace dialog...
#44 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Mark Baines | Date: 2006-06-10 17:06 | IP: IP Logged
Re: Selecting lines problem with left-click in left gutter, above.
Further to this, I have now discovered that if there isn't a blank line at the end of the file, I can't select the last 3 lines. If there is a blank line, then it is 2. This applies to most files, such as your English.ini.
But it's not always as simple as that.
One file has 6 long lines of wrapped text. Just ordinary ASCII text - notes for a letter.
I can select the 1st line which consists of 2 lines in the window.
I can select the 2nd line but again only the first screen line.
I can't select lines 3-6.
Another file is the AdBlock extension filter file for Firefox. It largely consists of regex though not entirely. The last 4 lines are:
/[\/.]ad-handler[\W\d\/.]/
vibrantmedia.com
/[\/.]ban(image|source)s?[\W\d\/.]/
reklama
I can select the first 1 but not the last 3.
and so it goes on...
#45 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-11 10:16 | IP: IP Logged
Mark Baines:
I have problem only with the last line. Not with more lines on the end of the file.
#46 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Bart | Date: 2006-06-11 11:35 | IP: IP Logged
Oh, ok my mistake. Thanks!
#47 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Mark Baines | Date: 2006-06-12 10:48 | IP: IP Logged
Mark Baines:
It is consistently 3 lines here as per message #44. It used to be the last line and assumed that the problem with the last 3 lines was a new bug. I have another file here where I can't select the last 13 lines, yes 13! DOS mode, ANSI code page, just line wrapped text.
#48 Re: PSPad unicode 4.5.2 (2221) English
Posted by: DJ N-4ceR | Date: 2006-06-16 13:44 | IP: IP Logged
n4cer:
Would be nice to be able to set the Font PSPad uses for Menu, Code Explorer, File Explorer, etc.
On my Laptop "Lucida Sans Typewriter 7pt" looks great for code and saves a lot of space on 1024x768 screen. So I wish I could set the rest to "Lucida Sans 7pt".
You can do it by the modify Language file. On the start you can see commented font name
This works fine for the file explorer, but not for the Code/Variable Explorer.
#49 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-25 08:07 | IP: IP Logged
DJ N-4ceR:
To set Editor (and related) font, go to menu Format/Font
