You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2221) English
Goto Page: 1 2 3 4 5 Next
#1 PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-04 21:38 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB) updated 2006-06-05 22:27 CET
Changes to 4.5.2 (2217)
News
new command line parameter: -U or /U for open source of the URL adress
modified Mark List (Shift+Ctrl+B)
Delete mark (Alt+Right) is back. New function - delete all marks added into menus
Ctrl+Left mouse in the left gutter creates mark
for each file is remebered 25 first marks or bookmarks in the File state. PSCache.BIN isn't compatible with the previous version. If any problem occurs, delete PSCache.bin file
the next/previous mark function (Alt+Up/Down) allows cycle
new bracket highlight + pair words highlight (in several languages yet). I am awaiting suggestions
new Code explorer for the Unix Shell Script
Corrections
PSPad accepts file with normal slash in path as the cmmand line parameter
Search/Replace problem if you replace with a empty string. Next correction of replace will follow
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
Edited 1 time(s). Last edit at 2006-06-05 20:27 by pspad.
#2 Re: PSPad unicode 4.5.2 (2221) English
Posted by: stefan gabos | Date: 2006-06-04 22:02 | IP: IP Logged
matching brackets don't get highlighted
#3 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-05 03:53 | IP: IP Logged
Highlighter name ?
#4 Re: PSPad unicode 4.5.2 (2221) English
Posted by: naputtelija | Date: 2006-06-05 04:52 | IP: IP Logged
Bracket highlightning does not work in HTML multihighlighter (at least with css and vbscript code in HTML)
Edited 1 time(s). Last edit at 2006-06-05 04:52 by naputtelija.
#5 Re: PSPad unicode 4.5.2 (2221) English
Posted by: Ilya | Date: 2006-06-05 07:22 | IP: IP Logged
Bracket matching highlightning doesn't work in TCL highlighter
#6 Re: PSPad unicode 4.5.2 (2221) English
Posted by: stefan gabos | Date: 2006-06-05 09:06 | IP: IP Logged
Bracket highlighting doesn't work for PHP
#7 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pjj | Date: 2006-06-05 10:25 | IP: IP Logged
Bracket highlighting works fine for me with PHP highlighter; it doesn't for XHTML multi, though.
#8 Re: PSPad unicode 4.5.2 (2221) English
Posted by: MrSpock | Date: 2006-06-05 14:42 | IP: IP Logged
The -u switch doesn't work for me. PSPad says it can't connect to the internet. Other programs can, though; and PSPad can open a file when I choose "open URL" from file menu.
I'm using a router, maybe that's why.
But it's not important for me, anyhow. If nobody else complains, don't bother.
#9 Re: PSPad unicode 4.5.2 (2221) English
Posted by: pspad | Date: 2006-06-05 19:10 | IP: IP Logged
MrSpock:
This option works, in other case PSPad doesn!t want to connect to internet tongue sticking out smiley Check Program settings / Internet, if correct proxy is set.
#10 Re: PSPad unicode 4.5.2 (2222) English
Posted by: pspad | Date: 2006-06-05 20:34 | IP: IP Logged
PSPad 4.5.2 (2222)
This package contains PSPad.exe only and corrects main problems of the (2221) build.
Main packege in this thread was updated and contains build (2222) too.
