You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.2 (2217) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.2 (2217) English
Posted by: Stefan | Date: 2006-06-03 22:02 | IP: IP Logged
language ini question:
;;Translate
lWriteToDir_Caption=write to PSPad folder
Means this "needs write access to main PSPad.ini in
maybe "C:\Program files\PSPad\" instead of the ini in user profile" ?
#22 Re: PSPad unicode 4.5.2 (2217) English
Posted by: Stefan | Date: 2006-06-03 23:03 | IP: IP Logged
Stefan:
;;Translate
I just read the thread from build 2214... i will try
to find the answer and the understanding there grinning smiley
BTW FYI:
I call and translate the new
"unlimited count of the unnumbered bookmarks"
into "yellow JumpMarks" to diff this from the 10 red "BookMarks"
#23 Re: PSPad unicode 4.5.2 (2217) English
Posted by: pspad | Date: 2006-06-04 05:56 | IP: IP Logged
OK. We can make a differences in terms:
bookmark - red numbered mark
mark - yellow general mark
#24 Re: PSPad unicode 4.5.2 (2217) English
Posted by: ikc666 | Date: 2006-07-24 21:22 | IP: IP Logged
Hello, I use PSPAD 4.5.2 (2228) and I've a similar trouble: I try to search and replace a regular expression in a sql file (same troubles with vbs and txt files). The searched expression is [$$] to be replaced by[\n]. The bug is that PSPAD pulls down the lines by the number of searched expressions. ie: if I have the following lines:
Quote:
USE Db_TEST
GO
I obtain the following result (assuming cursor is at the top of the file) and the msgbox says that regular expression was replaced 3 times (replace "." by an CRLF):
Quote:
USE Db_TEST
GO
By the way, the bug with endless loop is no more active in this version. It not a critical bug now, but a cosmetic one for me.
Many Thanks for your excellent software.
winking smiley
