You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2217) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.2 (2217) English
Posted by: pspad | Date: 2006-05-28 18:05 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.2 (2214)
Corrections
clip variables can contain underscore char
mark shortcuts Alt+Left/Right/Up/Down didn't work if you run empty PSPad
missing keywords in the MS-Dos Bat highlighter
partially increased Search speed
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
#2 Re: PSPad unicode 4.5.2 (2218) English
Posted by: pspad | Date: 2006-05-28 18:13 | IP: IP Logged
I prepare test build for the Windows 64 users.
This package contains PSPad.EXE only with a different memory manager. No other changes are made compare to build 2217
#3 Re: PSPad unicode 4.5.2 (2217) English
Posted by: imiglikos2 | Date: 2006-05-28 19:38 | IP: IP Logged
Hi Jan,
at first, there is still a strange behavior in replace:
my original html/php-string was still something like this:
<div id="public_site_footer">
<div id="psf_z1"><a href="<?= createLink('impressum.php',true) ?>" >Impressum</a> | <a href="<?= createLink('agb.php',true) ?>" >AGB</a> | <a href="<?= createLink('datenschutz.php',true) ?>" >Datenschutz</a> | <a href="<?= createLink('unser_team.php',true) ?>" >Das Team</a> | <a href="<?= createLink('presse.php',true) ?>" >Presse</a> | <a href="<?= createLink('verrueckte_ding.php',true) ?>" >Das Verr&uuml;ckte Ding</a></div>
</div>
I try to replace the ",true" with "nothing" (blank string) in the entire scope (no more options choosen). As result I get "replaced 6x" and this output-file:
</div>
instead of<?= createLink('impressum.php') ?>and so on.
Second, as a suggestion for the tool panel: Is it possible to save width of the panel even if panel is closed and programm is going to be restarted? Each time I have to resize my panel because of the numerous open/close of panel and PSPad. Or is there another way to set up the standard width?
Third: Is code folding still on your huge list of things all users are begging for?
Otherwise - really great work.
#4 Re: PSPad unicode 4.5.2 (2217) English
Posted by: Nelson | Date: 2006-05-29 01:42 | IP: IP Logged
imiglikos2:
I second that.
Besides, I also hope PSPad can remember which tab is used last time.
#5 Re: PSPad unicode 4.5.2 (2217) English
Posted by: McBain | Date: 2006-05-29 13:55 | IP: IP Logged
I would love to be able to put the whole tool-panel (with all tabs) on the right site of the screen.
Or is this already possible?
#6 Re: PSPad unicode 4.5.2 (2217) English
Posted by: tdusem | Date: 2006-05-29 20:00 | IP: IP Logged
The editor setting for Search result position is not working. Search always positions the found string at the bottom of the window, ignoring the setting.
#7 Re: PSPad unicode 4.5.2 (2217) English
Posted by: MrSpock | Date: 2006-05-29 22:27 | IP: IP Logged
imiglikos2:
I have only noticed it when replacing with an empty string, right? But in any event it is somewhat annoying.
On the other hand, PSPad is so powerful it can even compensate this bug: I've set up Notepad2 as an external program, open my file in it via doubleclick fom the tools panel, replace, save, close, and answer "Reload from disk" to the External Change Notification in PSPad.
That's pretty much it.
#8 Re: PSPad unicode 4.5.2 (2217) English
Posted by: pspad | Date: 2006-05-30 05:59 | IP: IP Logged
MrSpock:
This problem is corrected yet. Wait for the next build
#9 Re: PSPad unicode 4.5.2 (2217) English
Posted by: Mark | Date: 2006-05-30 06:34 | IP: IP Logged
Nelson:
I would prefer the real tab setting be a highlighter setting. When I do c++ coding I use real tabs, when I do VB coding I use spaces. Or a second option would be to make a smarter real tabs setting that will use real tabs if the file already has real tabs.
Keep up the good work PSPad is the best editor I have found at any price.
#10 Re: PSPad unicode 4.5.2 (2217) English
Posted by: jusid | Date: 2006-05-30 09:10 | IP: IP Logged
The search speed in opened file is still far from optimal. Search speed in version 4.5.1(2) is much slower (maybe 10x slower) than in version 4.3.3 which I used before.
Serach in files looks good. I did not notice any speed difference comparing to 4.3.3 version.
I hope it will be fixed. PSPad is cool smiling smiley
