You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2214) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.2 (2214) English
Posted by: kentez | Date: 2006-05-24 13:15 | IP: IP Logged
Jonas:
Relace in files does not work for me in build 2215.
Jonas.
Thank you for the exact description. What doesn't work ?
The thing is that the replace isn't work.. for me..
For example in text:
a,b,c,d
If you choose to replace , by ,\n (using regular expressions) the result is:
a,
b,c,c
In fact it replace 3 ',' but not in right place... This should be happen??
#22 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-24 18:11 | IP: IP Logged
to Kentez:
Jonas doesn't write about reg.expressions, but about replace in files
#23 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Henry | Date: 2006-05-25 12:05 | IP: IP Logged
I think the code sync to editor is great. Great Job !!!!
But after using it for a while, I think the code sync should be located in the mouse right click menu.
What do others think?smiling smileysmiling smiley
#24 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Jume | Date: 2006-05-26 19:05 | IP: IP Logged
a little question, just to help me translate into something more convenient:
"write to pspad folder" options can be described as global options independent of multiuser environment? i mean, actually the options that needs that right are stored in pspad_mu.ini, which means even in multiuser environment those options are global to everyone, am i wrong? well even if im wrong in concept but the effect (side effect then?) is as described, it serves fine to make sense when translating...
#25 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Mark Baines | Date: 2006-05-26 19:10 | IP: IP Logged
I don't know when this appeared, whether in this version or a previous.
In the thread "SUGGESTION: Comment / Uncomment a BLOCK of text (not individual lines)" you told me how to make a Block Comment for CSS files:
[/*...*/ | Block comment]
I now find that this doesn't work. If I Ctrl+Space or middle-click on a line (highlighted or not) the characters /**/ appear within the line together, rather than at either end.
#threadpane-splitter {
/**/ min-height: 3px !important;
This did work in earlier versions. The CSS.def file hasn't chnaged at all since I first amended it.
Thanks
#26 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-27 08:11 | IP: IP Logged
Jume:
For some options are rights to write to the PSPad folder neccessary.
In the case you select multiuser environment, config files except PSPad_MU.INI are stored in the user profile.
#27 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Stefan | Date: 2006-06-03 23:27 | IP: IP Logged
Jume:
Here's my try to translate into german:
;;Translate
lAdminRights_Caption=admin rights
lAdminRights_Caption== Benötigt Adminrechte
lAdminRights_Caption== admin rights needed
;;Translate
l3states_Caption=3-state control
l3states_Caption== Schalter mit 3 Optionen
l3states_Caption== Switch with 3 options
;;Translate
lWriteToDir_Caption=write to PSPad folder
lWriteToDir_Caption== Benötigt Schreibrechte > MU.ini
lWriteToDir_Caption== write access needed > MU.ini
;Zugriff auf PSPad-Ordner
