You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2214) English
Goto Page: Previous1 2 3 Next
#11 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Jürgen Falch | Date: 2006-05-23 16:45 | IP: IP Logged
FYI: movefile (www.sysinternals.com) IMHO makes it somewhat simpler to replace the context menu handler (PSPadShell.dll), at the cost of an additional reboot.
#12 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 18:17 | IP: IP Logged
You don't need reboot to change context handler.
I hope actual context handler will stay some time untached
#13 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Nelson | Date: 2006-05-23 18:29 | IP: IP Logged
To Nelson:
1. OK
2. I forgot localize this string in the PSPad. In language file it exists.
3. this string is in the Chinese language file (included with build) marked as the ;;Translate
4. same as 3)
How do you do translation ?
Each time I release new build, I compile all language files, missing strings are added into it and marked with ;;Translate comment.
If you open included language file and search for the ;;Translate string, you localize several strings only and remove ;;Translate comments. You must be ready up to 5 minutes
2. Then, what does it mean? I can't read Czech.
3. and 4.
I'm sure I have translated them, did you also forget to localize these strings in PSPad?
I use the "PSPad->diff" function to compare the latest English.ini and my ChineseBig5.ini.
(Because I often modify my own Chinese file to make it better, I don't use the Chinese file including in the build.
Then I update the language file every 2 or 3 builds.)
And two more things.
1. "System integration->Cascaded context menu" should be disabled when "Register in System context menu" is disabled.
2. Where is the "write to PSPad folder" option?
I noticed that it's a new string, but I can't find the option.
Edited 1 time(s). Last edit at 2006-05-23 18:37 by Nelson.
#14 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 18:53 | IP: IP Logged
Nelson:
1. you can have it registered and then you can switch between cascaded and non cascaded context menu - you need right to write into PSPad folder only, not admin rights
2. it's help on the bottom of the PSPad Program Settings dialog
#15 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Nelson | Date: 2006-05-24 02:10 | IP: IP Logged
Nelson:
1. You may misunderstand me. I know what they are.
What I meant is that when user uncheck "Register in System context menu", the "Cascaded context menu" should be disabled. Right?
The "Cascaded context menu" should be enabled only when the "Register in System context menu" is checked.
2. OK, I know where it is.
But what does it mean?
And, in the "key map" page, the "Project->Skryt projekt" is still there.
#16 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-24 04:46 | IP: IP Logged
"write to PSPad folder" means you need right to write into PSPad folder, because cascaded/non cascaded context menu settings is stored in PSPad_MU.ini and this file is in the PSPad folder
Edited 1 time(s). Last edit at 2006-05-24 04:47 by pspad.
#17 Re: PSPad unicode 4.5.2 (2214) English
Posted by: ;Op | Date: 2006-05-24 08:59 | IP: IP Logged
I discover a problem with "Swap with line below" and "Swap with line above" commands: when line wrapping is on, moving (using the 'swap...' commands) a wrapped line within other wrapped lines causes part of these other wrapped lines to be deleted. Situations where I saw the bug occur:
* Swapping a wrapped line N with line below when line N+1 is also wrapped
* Swapping a wrapped line N with line above when line N-1 is NOT wrapped and N-2 IS wrapped
#18 Re: PSPad unicode 4.5.2 (2214) English
Posted by: kentez | Date: 2006-05-24 11:23 | IP: IP Logged
Replacing text with regular expressions there are some cases and some expressions that you can't replace.
For example, using the reqular expression:
-> ">$ <message text = "
I can't replace this:
50106">
<message text = "
xxxxxx"/>
there are another way?
#19 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Jonas | Date: 2006-05-24 11:28 | IP: IP Logged
Relace in files does not work for me in build 2215.
Jonas.
#20 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-24 11:40 | IP: IP Logged
Jonas:
Jonas.
Thank you for the exact description. What doesn't work ?
