You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2214) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 05:12 | IP: IP Logged
Download link: pspad.cincura.net (1.6 MB) updated 2006-05-23 20:56 CET
Changes to 4.5.2 (2211)
News
you can create any count of the bookmarks - set/unset Alt+Left, delete all Alt+Right (confirmation - Program settings/Dialogs)
new User highlighter comment style - Forth
Corrections
Unix Shell script highlighter - keywords highlighting
interactive clips, open dialog and enclose file name into double quotes
windows switching exception with one window only
empty content of a file if project settings / UTF-8 as default CP and file wasn't in the UTF-8
hang-up after compilation with errors if file with error wasn't open
HTML reformat - spaces in formated code
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
Edited 1 time(s). Last edit at 2006-05-23 18:58 by pspad.
#2 Re: PSPad unicode 4.5.2 (2214) English
Posted by: sfoc | Date: 2006-05-23 06:14 | IP: IP Logged
bookmarks are lost after Ctrl+R
Text in MessageBox for delete all bookmarks in czech
why is no number displayed for each bookmark?
thanks
#3 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pjj | Date: 2006-05-23 06:27 | IP: IP Logged
Many thanks for the new build, Jan!
I rarely use project tree, but I have done this morning and found something, which looked like a bug and behaved like one, too winking smiley
With project pane open, if I switch to another app and come back to PSPad I can see all files with their paths, not just filenames (as they were when I left PSPad). When I click on any of them, paths of _other_ files disappear and only path to selected (cliked) file is visible. Now, when I click another filename, its path becomes visible, while the previous file's stays, too. Later clicking reveals that only paths of two files (the latest and the latest but one) are shown (some paths are not erased completely, so one can see what was left out of them, when using the horizontal scrollbar...).
I use W2K, if this info can help.
#4 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 06:43 | IP: IP Logged
sfoc:
thanks
There are 2 bookmarks set - 10 numbered bookmarks (Shift+Ctrl+n, Ctrl+n) and unlimited count of the unnumbered bookmarks - are not stored after file is closed.
I will add functionality to keep bookmarks after reopen file
Czech confirmation - I forgot to load string from localization
#5 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 06:44 | IP: IP Logged
Send me screenshot please
#6 Re: PSPad unicode 4.5.2 (2214) English
Posted by: sfoc | Date: 2006-05-23 06:55 | IP: IP Logged
pjj:
i confirm XP Prof SP2
#7 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Anonymous User | Date: 2006-05-23 08:34 | IP: IP Logged
So do I.
#8 Re: PSPad unicode 4.5.2 (2214) English
Posted by: Nelson | Date: 2006-05-23 11:09 | IP: IP Logged
1. Can you move the "admit right" label a little bit to left?
I need more space to translate it to Chinese.
2. There is a "zapis do adresa?e PSPadu" label, what is it?
I guess it means "restart PSPad to take effect", but where to insert to language file?
3. In hotkey mapping page, "Bookmark->Delete all bookmarks".
Should it be translated? If so, where to insert to the language file?
4. Also in the hotkey mapping page, "Project->Skryt projekt".
What does it mean and where to insert to the language file?
#9 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 16:27 | IP: IP Logged
To Nelson:
1. OK
2. I forgot localize this string in the PSPad. In language file it exists.
3. this string is in the Chinese language file (included with build) marked as the ;;Translate
4. same as 3)
How do you do translation ?
Each time I release new build, I compile all language files, missing strings are added into it and marked with ;;Translate comment.
If you open included language file and search for the ;;Translate string, you localize several strings only and remove ;;Translate comments. You must be ready up to 5 minutes
#10 Re: PSPad unicode 4.5.2 (2214) English
Posted by: pspad | Date: 2006-05-23 16:35 | IP: IP Logged
pjj:
There is a redrawing problem. I will update this build today
