You are here: PSPad forum > Developer forum - new builds > Re: PSPad unicode 4.5.2 (2211) English
Goto Page: Previous1 2 3
#21 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Joey | Date: 2006-05-15 00:39 | IP: IP Logged
It worked fine for myself.
Strange.
#22 Re: PSPad unicode 4.5.2 (2211) English
Posted by: McBain | Date: 2006-05-15 07:18 | IP: IP Logged
Joey:
Strange.
Your cursor is placed behind the last }-bracket (or in this line).
OK, I try a new description, maybe there's the problem.
Add the Code as before in a new PHP-document.
Put the cursor behind "{" (-> both brackets are highlighted)
Select the {-bracket (-> the selected {-bracket is now dark-blue and the }-bracket is still blue-highlighted)
Put the cursor to "if" -> {-braket is no more highlighted but the }-bracket is.
Hope you can reproduce it now.
This happens on at least 2 PCs im working on.
McBain
#23 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Jume | Date: 2006-05-15 11:35 | IP: IP Logged
it can be reproduced, what is left is to know whether is synedit problem or not
1.- select that { with keyboard or not, doesnt matter
2.- move the cursor to anywhere BEFORE the symbol, not only the same line, and WITH THE MOUSE, with keyboard will not reproduce it as well as setting the cursor after the symbol
#24 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Massimo | Date: 2006-05-15 17:51 | IP: IP Logged
I've reproduced it.
you must select first bracket with mouse, then click with mouse on "if": the second bracket is on.
#25 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Markus | Date: 2006-05-16 11:39 | IP: IP Logged
Hi, one problem with the normal "search and replace"...: I'd like to search in the following code for "true" (or ",true") and replace all with a blank string ("") (No futher options selected). I get 9 hits, but the new code is something like:
<div id="public_site_footer">
The original code was:
<div id="psf_z1"><a href="<?= createLink('impressum.php',true) ?>" >Impressum</a> | <a href="<?= createLink('agb.php',true) ?>" >AGB</a> | <a href="<?= createLink('datenschutz.php',true) ?>" >Datenschutz</a> | <a href="<?= createLink('unser_team.php',true) ?>" >Das Team</a> | <a href="<?= createLink('presse.php',true) ?>" >Presse</a> | <a href="<?= createLink('verrueckte_ding.php',true) ?>" >Das Verr&uuml;ckte Ding</a></div>
<div id="psf_z2"><a href="<?= createLink('regionalverzeichnis/index.php',true) ?>">Regionalverzeichnis</a> | <a href="<?= createLink('unternehmen.php',true) ?>" >Unternehmensanfrage</a> | <a href="<?= createLink('affiliate.php',true) ?>" >Webmaster-Partnerprogramm</a></div>
#26 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Fred | Date: 2006-05-17 05:06 | IP: IP Logged
Can confirm that, looks like multiple replacements in one line with zero string results in bad replace.
#27 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Ivo | Date: 2006-05-18 07:01 | IP: IP Logged
Little bug with replace function.
When i try to replace something with "nothing" (for example, to erase tab characters from a text), from this release (2211) the entire line is replaced, minus the last char... very strange!
And when i replace something 2 times, the second time the first line is unavailable...
Ivo
#28 Re: PSPad unicode 4.5.2 (2211) English
Posted by: ae | Date: 2006-06-02 08:34 | IP: IP Logged
Perl highlighter doesn't support multiline strings
I don't know what did you fixed here but i've got all of my perl code highlighted as comments now yawning smiley
#29 Re: PSPad unicode 4.5.2 (2211) English
Posted by: pspad | Date: 2006-06-02 09:37 | IP: IP Logged
ae:
Send me source sample
