You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.2 (2211) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.2 (2211) English
Posted by: pspad | Date: 2006-05-10 20:09 | IP: IP Logged
Download link: pspad.cincura.net (1.1 MB)
Changes to 4.5.1 (2207)
News
Program settings / System - you can set Cascaded system context menu
new icons for the Code explorer, Clipboard monitor, ...
Code explorer - new button - synchronize with code - will locate item in the code explorer coresponding to line in the editor
Corrections
corrected replace with a new line (code Wang Guan Mmou). It isn't necessary to replace with a backward direction - report any problem
Cobol Code explorer - numbers in the names, count in different styles of Cobol source code
VBScript Code explorer - "property let"
missing ");" in the Text to JScript function
printing problems with a dark background
Clipboard monitor doesn't support unicode
Text diff from "outside" if file(s) already open
highlight matching brackets
clips for the TXT files
Perl highlighter doesn't support multiline strings
simple text - wordwrap split words, containing single quote (e.g. cat's)
Context menu handler update
1. close Windows Explorer, Total Commander e.t.c.
2. run PSPad, go to the Program settings / System and uncheck [x]Integrate with a Right mouse click
3. close PSPad
4. open Explorer (Total Commander, ...) and replace PSPadShell.DLL with a new one
5. run PSPad and activate option in the Program settings / System
#2 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Nelson | Date: 2006-05-11 03:31 | IP: IP Logged
Missing this string in the language file.
Can you tell us where to insert the string into the language file?
3. close PSPad
Good job!
#3 Re: PSPad unicode 4.5.2 (2211) English
Posted by: pspad | Date: 2006-05-11 04:28 | IP: IP Logged
I am sorry, I forget regenerate other languages
the string is on the bottom of the [settings] section:
cShellSubmenu_Caption=Cascaded context menu
#4 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Ilya | Date: 2006-05-11 05:30 | IP: IP Logged
Thre is a small sad smiley in "Programm Settings..."->"System integration"->Line3.
#5 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Nelson | Date: 2006-05-11 05:50 | IP: IP Logged
Ilya:
That's the problem I posted before smiling smiley
You have to manually open your language file (Ex: English.ini or so) in the Lang folder, find the [Settings] section, and paste this string to the bottom of the section.
Then, save the language file and restart PSPad, done. tongue sticking out smiley
Edited 1 time(s). Last edit at 2006-05-11 05:51 by Nelson.
#6 Re: PSPad unicode 4.5.2 (2211) English
Posted by: pspad | Date: 2006-05-11 06:00 | IP: IP Logged
I updated latest build. Missing string is added into all languages.
#7 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Ilya | Date: 2006-05-11 07:17 | IP: IP Logged
May all of your problems will be like this onesmiling smiley
#8 Re: PSPad unicode 4.5.2 (2211) English
Posted by: tdusem | Date: 2006-05-11 14:11 | IP: IP Logged
Thanks for fixing the printing color. I can read my printouts again.
#9 Re: PSPad unicode 4.5.2 (2211) English
Posted by: Mark Baines | Date: 2006-05-11 17:51 | IP: IP Logged
New File... dialog at startup. Select 'Recent Files' tab. Now resize, say sideways. Doesn't redraw properly here, lots of scattered letters but mostly blank space.
#10 Re: PSPad unicode 4.5.2 (2211) English
Posted by: pspad | Date: 2006-05-11 18:12 | IP: IP Logged
Mark Baines:
This should be related of the graphic adapter. I try to solve it.
