You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2207) English
Goto Page: Previous1 2
#11 Re: PSPad unicode 4.5.1 (2207) English
Posted by: pspad | Date: 2006-05-07 05:40 | IP: IP Logged
Crimson has a bigger line space.
Go to the Program settings / Direct edit button
increate value of the variable: ExtraLineSpacing=2
#12 Re: PSPad unicode 4.5.1 (2207) English
Posted by: G=A | Date: 2006-05-07 05:46 | IP: IP Logged
Sorry to miss the explanation of the problem here. I open the same file in different editor (as you can see in the file name and line number). But in PSPad the chinese character wouldn't show up. I tried change font, change format, it just wouldn't show the character. I search the forum and found no others has the same problem.
Thank you for correcting the image thing.
#13 Bug in "PHP highlighter" and "HTML Multihighlighter"
Posted by: bugged | Date: 2006-05-10 10:46 | IP: IP Logged
Underscores between comment tags are not visible.
Examples:
off: // $my_var
on: // $my var
off: /* $my_var */
on: /* $my var */
#14 Re: Bug in "PHP highlighter" and "HTML Multihighlighter"
Posted by: pspad | Date: 2006-05-10 11:10 | IP: IP Logged
bugged:
Read my previous answer. There is advantage how to correct it.
It depends of the used font.
#15 Re: Bug in "PHP highlighter" and "HTML Multihighlighter"
Posted by: bugged | Date: 2006-05-10 11:35 | IP: IP Logged
You were right. I configured the PHP comment style as not being italic and it's ok now. Quite annoying (everything was ok in previous builds, if I remember well). Thank you winking smiley
