You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2207) English
Goto Page: 1 2 Next
#1 PSPad unicode 4.5.1 (2207) English
Posted by: pspad | Date: 2006-05-01 05:52 | IP: IP Logged
New full release of the PSPad editor 4.5.1
CAB archive: pspad.cincura.net
Installer: www.webattack.com
Whats new: www.pspad.com
#2 Re: PSPad unicode 4.5.1 (2207) English
Posted by: Ilya | Date: 2006-05-01 06:40 | IP: IP Logged
Hi Jan,
Thank you for the new release. smiling smiley
I found a small bug. sad smiley
The changing of "Sort Code explorer results alphabetically" checkbutton at "Program Settings.."->"Tools" screen doesn't activating the "Apply" button.
#3 Re: PSPad unicode 4.5.1 (2207) English
Posted by: MrSpock | Date: 2006-05-01 14:54 | IP: IP Logged
Thanks for the new build!
Clips in txt files still do not work when the open txt file is loaded from disk, only when it is newly created inside PSPad. I'm starting to wonder if this has just slipped from your todo list, or if it's something really difficult to fix. Is there any way I could help? I hope I'm not too annoying ... sad smiley
Jan Schreiber
#4 Re: PSPad unicode 4.5.1 (2207) English
Posted by: MHS | Date: 2006-05-04 20:41 | IP: IP Logged
Same problems with clips for me. In 2206 version, this problem was solved. I'm waiting for next build ...
Best regards, Martin
#5 Re: PSPad unicode 4.5.1 (2207) English
Posted by: stefang | Date: 2006-05-05 08:16 | IP: IP Logged
Hi Jan,
In the newer versions the bookmarking is not working anymore. In the previous build it worked from time to time (after a restart) but now it's not working at all.
#6 Re: PSPad unicode 4.5.1 (2207) English
Posted by: HL | Date: 2006-05-05 08:23 | IP: IP Logged
stefang:
Hi Jan,
ALT + left etc. works for me *IF* ALT works, see thread for version 2205
#7 Re: PSPad unicode 4.5.1 (2207) English
Posted by: jdub | Date: 2006-05-05 15:51 | IP: IP Logged
Ctrl-K and Shift-Ctrl-K both STILL append an extra line when reformatting single paragraphs. I don't know when this behavior changed, but it ain't good...
#8 Re: PSPad unicode 4.5.1 (2207) English
Posted by: Guest | Date: 2006-05-06 01:24 | IP: IP Logged
Jan, about this post, I made a mockup image of what I'm talking about:
#9 Re: PSPad unicode 4.5.1 (2207) English
Posted by: pspad | Date: 2006-05-06 19:58 | IP: IP Logged
This will be available in the next build
#10 Re: PSPad unicode 4.5.1 (2207) English
Posted by: | Date: 2006-05-07 04:03 | IP: IP Logged
Hi, Jan:
Here is the problem I met. I am not sure if it should be reported as a bug or I simply have not found the setting.
Moderator note. If you want to place images, use tag [ img ] (without spaces) or simply paste URL address, select it and push the IMG button bellow
Edited 1 time(s). Last edit at 2006-05-07 05:37 by pspad.
Goto Page: 1 2 Next
