You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2205) English
Goto Page: 1 2 3 Next
#1 PSPad unicode 4.5.1 (2205) English
Posted by: pspad | Date: 04/27/2006 06:37 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.1 (2205)
News
changes in the memory management and some internals optimalizations
Program settings / System - new option allows switch off PSPad scripting
New localizations: Norsk (Stein-Aksel Basma), Galician (Xabier Cancela)
Corrections
internal name stored by the PDB plugin contains full path
it was possible to edit splitted read only file
Remove redundant spaces function doesn't supports unicode
File format (Dos, Mac, Unix) was always DOS if file was empty. Now is set with a same rule as the New file
replaced '_' character in image name after insert into HTML
New Context menu handler
1. disable Program settings / System / [x]Integrate with Right mouse click
2. start PSPadShell_reg.bat from this package - it will register new PSPad context menu handler. Run PSPadShell_unreg.bat to unregister it.
Limitation:
1. you have to be a system admin to register DLL
2. context menu items selection isn't implemented yet
#2 Bug: TAB behaviour does not work correctly
Posted by: hoppfrosch | Date: 04/27/2006 10:30 | IP: IP Logged
Used Version: Build 2205
Don't know whether earlier builds show the same ...
I'm editing a perl script.
My Tab-Preferences are as following:
EditorSettings-Real Tabs: NO
EditorSettings-Smart Tabs: Yes
EditorSettings-Tab Width: 2
EditorSettings-Ident Width: 2
HighlighterSettings-Perl-TabWidth: 2
Assume I have a code sequence like this (Where @ represents the cursor position, _ represents VISIBLE Spaces):
____foreach my $test (@array}) {@
____}
Pressing return generates following:
____@
____}
Thats OK so far - but when pressing TAB in this situation this results in:
____________@
____}
This is not correct: a 8space wide REAL TAB is inserted instead of 2 REAL SPACES (as expected from the settings) ...
Edited 4 time(s). Last edit at 04/27/2006 10:40 by hoppfrosch.
#3 Bug: No recognition of externally changed files
Posted by: hoppfrosch | Date: 04/27/2006 10:38 | IP: IP Logged
PSPad does not recognize anymore, if a file opened in PsPad was changed externally. I'm sure in earlier version this worked ...
Edited 1 time(s). Last edit at 04/27/2006 10:44 by hoppfrosch.
#4 Re: Bug: No recognition of externally changed files
Posted by: Nelson | Date: 04/27/2006 11:06 | IP: IP Logged
Hi, there is a new setting called "Integrated scripting support (WSH)".
Can somebody tell me what it means?
I need to know it so that I can translate it. smiling smiley
#5 Re: Bug: TAB behaviour does not work correctly
Posted by: Jume | Date: 04/27/2006 11:08 | IP: IP Logged
hoppfrosch:
____}
____@
____}
____________@
____}
try deactivating smart tabs
#6 Re: Bug: No recognition of externally changed files
Posted by: Lolo | Date: 04/27/2006 11:10 | IP: IP Logged
hoppfrosch:
I don't have any problem with that feature.
#7 Re: Bug: TAB behaviour does not work correctly
Posted by: hoppfrosch | Date: 04/27/2006 11:48 | IP: IP Logged
Jume:
Everything seems to be OK then - but the described behaviour with SmartTabs activated seems to be a bug anyway ...
Edited 1 time(s). Last edit at 04/27/2006 11:49 by hoppfrosch.
#8 Re: Bug: No recognition of externally changed files
Posted by: hoppfrosch | Date: 04/27/2006 11:51 | IP: IP Logged
Lolo:
Strange - since the files have REALLY changed, and PsPad does NOT recognize this on my machine. sad smiley
#9 Re: Bug: No recognition of externally changed files
Posted by: hoppfrosch | Date: 04/27/2006 12:10 | IP: IP Logged
hoppfrosch:
yawning smiley It becomes weird now: the changes are detected again from PsPad (I cannot remember any action which could "reanimate" this feature: no reboot, no login/logout, same applications running(?) ...)
Forget this bug - I'll watch it on my machine and try to find the reason
#10 Re: Bug: TAB behaviour does not work correctly
Posted by: pspad | Date: 04/27/2006 12:50 | IP: IP Logged
hoppfrosch:
Open help and read about smart tabs.
Quote from the help:
Smart Tabs
When checked, each TAB press will cause the cursor to follow words from previous line. When the cursor moves past the end of the previous line then TAB adds the normal amount of space, determined by the Tab Width setting.
