You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2203) English
Posted by: Bart | Date: 2006-04-23 09:17 | IP: IP Logged
Hi Jan,
found an old bug in this version: when dragging a image named like "button_top.gif" PSPad inserts "button%5Ftop.gif" instead. You fixed this bug some times ago.
There is a problem with the HTML parser too, it can't parse ul - li - ul -li structures correct.
Example:
<ul id="mainmenu">
<li id="mainmenu_item">
<ul id="submenu">
<li id="submenu_item"></li>
</ul>
</li>
<ul id="submenu">
</ul>
</li>
<ul id="submenu">
</ul>
</li>
</ul>
or take a look at the dropdown menu of www.humboldttoursberlin.de .
This week i have a hard job about editing a great handwritten site because PSPad did not have a extended replace (replacing complete code blocks) like HomeSite has:
web.bentley.edu
What I'm always looking too is SFTP support ;)
Anyway PSPad is my favorite any time!
Posted by: fafek2 | Date: 2006-04-23 11:43 | IP: IP Logged
Jume:do not misunderstand it, LEFT ALT KEY is simply ALT, while RIGHT ALT KEY (ALT GR) is not, ALT GR is the same as pressing CTRL+ALT, maybe your problems comes from there
I am pressing Alt+S (for example), and this calls a function assigned to CTRL+ALT+S.
I know I can write diacrytical marks also by pressing CTRL+ALT+letter, but I am writing them only using ALT key.
I think default key map should depend on chosen translation. It would correct also problems with translated menu bar hot keys and global hot keys.
Posted by: pspad | Date: 2006-04-23 11:50 | IP: IP Logged
Left ALT = ALT
Right ALT (ALTGR) = Ctrl+Alt
Why ? Ask the Microsoft support. I am not author of the operating system.
Posted by: fafek2 | Date: 2006-04-23 12:34 | IP: IP Logged
pspad:Left ALT = ALT
That's right, I forgot about this when I was reconfiguring program.
The next question is why do you use "Alt+" and "CTRL+ALT" shortcuts? I've been looking through other editors and almost no editor use "ALT+letter" combinations. It only cause problems.
Why not "CTRL+", "CTRL+Shift", "CTRL+SHIFT+ALT", "ALT+F3" and so on?
Year ago, when I first time installed PSPad, I unistalled it quickly when I noticed I can't use diacrytical marks.
Posted by: rb | Date: 2006-04-26 06:22 | IP: IP Logged
I often use ALT shorcuts. If these shortcuts aren't OK for you, just configure other keys, PSPAD is extremly configurable.
Posted by: Joe Belmaati | Date: 2006-04-26 13:03 | IP: IP Logged
Interestingly, I have noted some strange behavior from this version regarding the ALT shortcuts. It seems that my bookmark shortcuts (Alt-Left, Alt-Right, Alt-Up, Alt-Down) have stopped working.
Posted by: Cdrx | Date: 2006-04-26 17:32 | IP: IP Logged
I've got the same probleme.
But it seems to happen only when I open PsPad without editing any files at startup (with project or not). Strange
Posted by: Jume | Date: 2006-04-26 17:37 | IP: IP Logged
and here also those 4, 2 times already
first time everything went ok after reverting to default keymapping (maybe a imcompatibility between versions, dunno), a bit hmpf cause i had my own hotkeys for some things which i needed to reconfigure
the second time was with this last beta, but after a pspad restart it dissapeared (no needed to revert to default keys)
no clue about why, but it seems that in every case, default keys and/or pspad restart should work
