You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2200) English
Posted by: Typhoe | Date: 2006-04-05 08:48 | IP: IP Logged
pspad wrote:
> Deactivate option [x]Wrap with right edge
No, that's not what I expect.
I have a file with only one line in it:
aaaa aaaa aaaa aaaabbbb bbbb bbbb bbbbaaaa aaaa aaaa aaaabbbb bbbb bbbb bbbb
What I want is wrap the line by block of 19 caracters:
aaaa aaaa aaaa aaaa
bbbb bbbb bbbb bbbb
aaaa aaaa aaaa aaaa
bbbb bbbb bbbb bbbb
That was easy in v4.33, but I can't manage to do it in 4.5 and latest betas...
Regards,
Typhoe
Post Edited (04-05-2006 10:50)
Posted by: David Pratten | Date: 2006-04-05 09:50 | IP: IP Logged
Dear Jan,
Fantastic program.
I note that the program comes with initial settings that prevent the Alt+M shortcut key for the HTML menu from working. The clipboard monitor opens instead.
I would be clearer if one or the other was changed.
Thanks
David
Posted by: ra | Date: 2006-04-05 18:07 | IP: IP Logged
PSPad doesn't remember the last used tab in the tool"window" on the left side. I usually need FTP, but whenever I start version 2200 it is set to CodeExplorer. Would be nice if PSPad could remember the tab when closing the program.
BTW: ClipboardMonitor has to be made visible again, too, after every restart. It's okay, if it is disabled, but the tab should be there if it was there when I closed the program.
Thanks for your great work.
Posted by: Bart | Date: 2006-04-05 18:53 | IP: IP Logged
Hi Jan,
thanks for the new build. Just about the css formating compression:
instead of:
a:hover.nav {text-decoration: underline; color: #000033; }
a:active.nav {text-decoration: underline; color: #000033; }
.nav {font-family: Tahoma, sans-serif; font-size: 10px; color: #333333; }
i would prefer:
a:hover.nav { text-decoration:underline; color:#000033; }
a:active.nav { text-decoration:underline; color:#000033; }
.nav { font-family:Tahoma,sans-serif; font-size:10px; color:#333333; }
that means:
- no empty lines between the code lines
- a space after { -bracket; example: ".nav { font-fam..."
- no spaces between attribute: and value; example: color:#333333;
Posted by: pspad | Date: 2006-04-05 19:10 | IP: IP Logged
Please write it again into English forum. Here isn't the right place for discusion about your suggestion.
I made HTML reformat result as the TopStyle code.
Posted by: Dieter Menne | Date: 2006-04-05 19:23 | IP: IP Logged
Thanks, Jan, this version runs on Win2000 without crashing. IN the default 4.5, DrWatson comes up on startup (but I can continue) and very frequently in between.
Great work!
Dieter
Posted by: Dave | Date: 2006-04-05 19:27 | IP: IP Logged
Jan, In this version bookmarks aren't shown at start up but are refreshed when clicking on another file tab and back again.
Dave
Posted by: pspad | Date: 2006-04-05 19:34 | IP: IP Logged
I move your message into the bug forum, because you place it as the new topics into the beta forum
Posted by: PsychodelEKS | Date: 2006-04-07 13:18 | IP: IP Logged
Hi, Jan,
I've installed the new version recently and 've noticed, that my F1 hotkey binded to a script launches PSPad help also, it worked fine before =( It is not in the hotkeys list, so I think it's a bug, is it, or you've decided to make it hardcoded?
Though PSPad gets better and better from beta to beta. ;)
Posted by: pspad | Date: 2006-04-07 18:36 | IP: IP Logged
Program settings / Direct edit
NoF1HelpInEditor=1
