You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2199) English
Posted by: pspad | Date: 2006-03-29 20:59 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.1 (2191)
News
Program settings / Files / new option - Ignored file masks list (CVS, backups, ...). It works near in whole PSPad - Project from direcotry, Scripts, ...
missing options (Move, Resize) added into the TaskBar context menu
new variable F1InEditor in the [Special Settings] section - you can switch off help on F1 in the editor Window and use F1 for your purposes
added LIST -aL command for keep FTP connection alive
Fortran Highlighter - added new keywords
Char tab - added symbols (defined in Ascii.ini)
Corrections
program hang-up if some tools was active (e.g. Numeric base translator) and you open new file from "outside"
Save as behaviour
Log window behaviour
HTML TiDy and UTF-8 documents
JScript Code explorer for JScript - variables outside function, comments
Fortran Code explorer - Sort code explorer result option has no meaning
Posted by: Joe Belmaati | Date: 2006-03-29 21:49 | IP: IP Logged
I changed the value to 0 in PSPad.INI, but the file seems to revert to 1 after program re-launch. How do I make the change "stick"...?
[NVM] Found the solution - edit the file in another editor...
Post Edited (03-29-2006 23:58)
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: pspad | Date: 2006-03-30 03:34 | IP: IP Logged
Program settings / Direct edit buton
Posted by: Heiner Meiners | Date: 2006-03-30 07:37 | IP: IP Logged
Hi Jan,
After download and unpacking Build 2199 to PSPad directory I found the following:
1. I did a Find/Replace in Files (searching a string that occurs enough times to fill the search result list so there is a scrollbar shown to the right).
3. Move the cursor to the left of the Search in Files Results window (where the buttons for expand/collapse/open all are.
- The help text for the buttons is shown where otherwise the Code Page is displayed in the status line below.
4. When the cursor is moved back to any position that leads to redisplay the Code page in the status line, the 4 small rectangles in the status bar between cursor position information and character information are filled with blue background and strange content.
Maybe a buffer overflow of some kind?
Second: When compiling the log window now shows the progress of compilation, but no scrollbar is displayed.
HTH
Heiner
Posted by: Ilya | Date: 2006-03-30 08:13 | IP: IP Logged
On my PC I not observe it.
WinXP PRO SP2 ; P4 2.6GHz ; 512MRAM
Ilya
Posted by: ShiLong | Date: 2006-03-30 09:01 | IP: IP Logged
Hi Jan,
where can i define the comment string for Ctrl+Shift+A?
The symbol table is very usefull! Thank you!
Posted by: pspad | Date: 2006-03-30 09:29 | IP: IP Logged
In a user highlighter yes, in build-in highlighters no
Posted by: Lolo | Date: 2006-03-30 12:56 | IP: IP Logged
Hello Jan,
First of all, thank you very much for this new build.
I always a pleasure to discover new features (long life to PSPad)
Otherwise, I have noticed something strange in hexadecimal mode.
Open any file directly in Hexadecimal editor.
Now have a look to the status bar.
You can see 00000000 (2:2) while I am on the first character.
Is it normal ?
Thanks and have a nice day.
Posted by: pspad | Date: 2006-03-30 18:19 | IP: IP Logged
No, it's not normal
Posted by: Neil | Date: 2006-03-30 21:42 | IP: IP Logged
Hi Jan,
-- comments do not work in 2199 or 2197.
works in all previous versions.
Thanks,
Neil
