You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2191) English
Posted by: jgodfrey | Date: 2006-03-21 14:52 | IP: IP Logged
MoMann wrote:
> jgodfrey,
> You’re correct that this is an extension of TCL; that said OOP
> is a key and fundamental aspect of programming.
MoMann,
I understand where you're coming from, and again, I don't mind additional keywords being added to the Tcl code explorer. My only point was that incrTcl is only one of *many* OO extensions available for the Tcl core language. Should we also start adding code explorer support for Snit, XOTcl, Stooop, OTcl, ClassyTcl, etc?
I guess it's just a matter of what gets requested, and what Jan is willing to do.
Again, just an observation...
Jeff
Posted by: bert | Date: 2006-03-21 18:54 | IP: IP Logged
The workaround of:
>PSPad can only replace character from bottom to top when you want to replace a >piece of text by a carriage return.
is known, but will there be a normal solution? Does it have priority for the programmer(s)?
Bert
Posted by: Anonymous User | Date: 2006-03-21 23:10 | IP: IP Logged
I thought this only occurred with read-only files, but it seems that Word Wrap is randomly disabled for no reason with all files. With read-only files it happens consistently though. I have the "Trim Trailing Spaces" option disabled. Is this a bug or is there something that I'm missing?
Posted by: Joe Belmaati | Date: 2006-03-22 08:27 | IP: IP Logged
bert wrote:
> The workaround of:
> Bert
A huge priority for me. I would really love to see this quirk ironed out, as I frequently have to format large text files.
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: scalpal | Date: 2006-03-23 12:26 | IP: IP Logged
The SHIFT+CTRL+I combination is not working for the indent block.
If I am using it form the Format menu, it is working, but with the key combination it doesn't work.
I can change the key combination in the Settings to SHIFT+CTRL+NUM -, but after I can't change back to SHIFT+CTRL+I, because in this case I get NONE instead of key combination.
Can you check it please, because, I would like to use it with the default key combination.
Thanks.
PSPAD version: 4.5.0 (2183 and 2197)
Posted by: Anonymous User | Date: 2006-03-23 13:05 | IP: IP Logged
If Ctrl+Shift+i isn't registering in the hotkey assignment field, this is most likely because you have it assigned to a windows shortcut or some function in another application.
Posted by: scalpal | Date: 2006-03-23 14:54 | IP: IP Logged
Hmmm, interesting, but how can I find, what is the other program which uses this combination?
Posted by: pspad | Date: 2006-03-24 01:07 | IP: IP Logged
In the help is the all shortcuts desription
Shift+Ctrl+I is used for Indent block (default)
Posted by: scalpal | Date: 2006-03-24 10:05 | IP: IP Logged
Yeah, I know, but not working for me....
The Shift+Ctrl+U is working correctly...
Posted by: ricky | Date: 2006-03-24 13:37 | IP: IP Logged
aïe! before downloading this version, the F1 key was assigned to a script of mine.
But now, my script don't worh anymore because F1 show PSPad help, even after unassigning F1 shortcut for contextHelp in PSPad options. very annoying for me.
thanks a lot for your good work ( done and to be done ...)
