You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2191) English
Posted by: pspad | Date: 2006-03-20 10:35 | IP: IP Logged
Problem occurs on the Windows 2000 only. I am looking for reason.
Posted by: Lolo | Date: 2006-03-20 14:20 | IP: IP Logged
Thanks for your answer.
I am waiting for the next release.
I am sure you will fix this bug quickly.
You are the best
See you soon.
Posted by: jgodfrey | Date: 2006-03-20 14:25 | IP: IP Logged
MoMann wrote:
> Can you please add "body" as a Code Explorer keyword in TCL/TK.
> This keyword is used to create functions like "proc" and
> "method".
Just to be clear - body is not a Tcl/Tk keyword. Apparently, it's an incrTcl keyword - with is an OO extension for Tcl. That said, I guess it'd be OK if it were added, but where do you draw the line?
Jeff
Posted by: Frank | Date: 2006-03-20 14:58 | IP: IP Logged
Open psPad, type 10 times 123 (123123123123123123123123123123). Now go to Search/Replace and replace 3 with \n (regexp on, no prompt). A popup will tell you that "3" was replaced 10 times, but on screen you'll see
12
This was with 2183, so I went for this beta (2191) but has the same problem...
Regards,
F
Posted by: Lolo | Date: 2006-03-20 15:25 | IP: IP Logged
Hello Frank,
it has been already discussed on the forum.
Simply go to the end of your sentence, hit Ctrl+H and replace 3 by \n
Check regular expression and especially direction to backward
Hit OK. PSPad will replace all 3 by a carriage return.
PSPad can only replace character from bottom to top when you want to replace a piece of text by a carriage return.
That's all.
Posted by: Frank | Date: 2006-03-20 15:36 | IP: IP Logged
OK, I looked but did not find this. My mistake. However, if this is the way to go, then why isn't it either implemented this way in the beta, or at least shown in a popup or something?
Great editor btw.
Frank
Posted by: MoMann | Date: 2006-03-20 15:39 | IP: IP Logged
jgodfrey,
You’re correct that this is an extension of TCL; that said OOP is a key and fundamental aspect of programming.
Also I write 95% in OO and my class files can get very big with methods, unfortunately the code explorer only identifies functions that start with either "proc" or "method"
At least with the body keyword I can select the method quickly.
Also not many or if any "FREE" text editors support TCL/TK like PSPAD, and I am very great full that Jan, has added TCL/TK features in the past and hopefully he will add this one also.
Thanks,
MoMann
Post Edited (03-20-2006 16:40)
Posted by: pspad | Date: 2006-03-20 21:35 | IP: IP Logged
Problem withs the Windows 2000 was fixed. Download build 2191 again
Posted by: Lolo | Date: 2006-03-21 09:00 | IP: IP Logged
Thanks a lot. Now it works very well on Windows 2000
Just for information, the splash screen of PSPad display 4.5.1 build 2197 instead of 2191 but it is not important.
Posted by: pspad | Date: 2006-03-21 09:24 | IP: IP Logged
I know, because it's really 2197
I sent build 2191 to BetaNews.com before
