You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2191) English
Goto Page: 1 2 3 4 5 Next
#1 PSPad unicode 4.5.1 (2191) English
Posted by: pspad | Date: 03/19/2006 09:30 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.1 (2187)
News
dictionary handling was changed, important is extension .DIC only (go to the SpellSettings (Ctrl+F7) and choose dictionary)
added new keywords into PERL highlighter
User highlighter - added ability switch off label highlight
User highlighter - new comment style $...$
Spell check settings - new button will navigate you to the dictionary download web page
added new keywords (PHP5) into PHP highlighter
changed default shortcut for the Delete word command from Ctrl+T to Ctrl+Del
speed up compiler run with [x]Catch external output
Corrections
Editor line height with and without highlighter
File tab - file name limit works for first 9 tabs only
Fotran comment (Shift+Ctrl+A) changed from '*' to '!'
registration was moved from HKCR into HKCU for WindowsXP and above. You can register file types, set PSPad into context menu with user rights without influence of other computer users
Drag/Drop file into TextDiff doesn't open a file
User highlighter - keywords can start with chars contained in the Alloved Keyword chars field
SpellCheck and exception after Add word to dictionary
C++ highlighter doesn't highlight Assembler block
F1 in the editor window doesn't show help
Multihighlighter was limited up to 250 000 chars, now depends of the HlUpToSize variable in the Special settings section
Clip list for plain text files (TXT.DEF)
Align block function removes EOL from the last selected line
LeftToPreviousLine in Special settings section doesn't work
FileSearch/Replace and unicode chars in modified lines
#2 Re: PSPad unicode 4.5.1 (2191) English
Posted by: zenmaster | Date: 03/19/2006 13:29 | IP: IP Logged
I reported this issue in the 'Bug Report' forum on 12-31-2005 15:21 for build (2175) :-
I have 'real tabs' unselected in Editor Settings.
If I open a file containing 'real tabs' it confuses the cursor position and I cannot cursor to the end of the line or select text correctly.
If I convert all tabs to spaces then everything is OK.
This problem remains in this version. I have to use version 4.3.
Could you please find a solution to this, as I really would like to use all the new features in 4.5.
Thank you.
#3 Re: PSPad unicode 4.5.1 (2191) English
Posted by: gogogadgetscott | Date: 03/19/2006 14:40 | IP: IP Logged
Is there any way you can add:
program setting / Confirmation / Close project file
#4 Re: PSPad unicode 4.5.1 (2191) English
Posted by: pspad | Date: 03/19/2006 14:50 | IP: IP Logged
Yes
#5 Re: PSPad unicode 4.5.1 (2191) English
Posted by: MoMann | Date: 03/19/2006 19:53 | IP: IP Logged
Can you please add "body" as a Code Explorer keyword in TCL/TK. This keyword is used to create functions like "proc" and "method".
Thanks,
MoMann
#6 Re: PSPad unicode 4.5.1 (2191) English
Posted by: pspad | Date: 03/19/2006 19:56 | IP: IP Logged
I don't knwo TCL/TK.
I need a souce code example
#7 Re: PSPad unicode 4.5.1 (2191) English
Posted by: MoMann | Date: 03/19/2006 20:02 | IP: IP Logged
Here you go:
body ixia::ixiaWriteToPort {} {
set procname "ixia::ixiaWriteToPort"
global DEBUG_SYSTEM ;
set dbg 0 ;
set dbg [expr $dbg + $DEBUG_SYSTEM + $SCOPE_DEBUG]
set portList [list [list $ixiaChassis $ixiaCard $ixiaPort]]
return [ixWritePortsToHardware portList];
Here is the url to know any specifics
www.tcl.tk
Thanks
MoMann
#8 Re: PSPad unicode 4.5.1 (2191) English
Posted by: Anonymous User | Date: 03/20/2006 09:01 | IP: IP Logged
Opening a read-only file causes Word Wrap to be turned off even if you have it enabled by default.
#9 Re: PSPad unicode 4.5.1 (2191) English
Posted by: Replika | Date: 03/20/2006 10:47 | IP: IP Logged
Can't use Extended Copy to quick copy line, It always Cut the line sad smiley
#10 Re: PSPad unicode 4.5.1 (2191) English
Posted by: Lolo | Date: 03/20/2006 11:21 | IP: IP Logged
I can't use this new version. PSPad always crash at start up.
I sent you the log file.
I have uninstalled it completely (even registry information) and reinstalled the version 4.5.0 build 2183.
PSPad work's very well.
Now if I decompress the new .cab into PSPad folder and launch the program, I have a crash sad smiley
I hope you could help me.
I have to go back to the previous version.
Have a nice day.
