You are here: PSPad forum > Developer forum - new builds > PSPad unicode 4.5.1 (2187) English
Posted by: pspad | Date: 2006-03-20 19:06 | IP: IP Logged
ashnur wrote:
> - i didn't found an easy solution for block comment for
> php,css,html
Ctrl+Space
> - cant use special chars when edit files.
I don't understand
> - cant change easily between char coding in file format
Why ? Click on the menu item isn't easy ?
> - there are problems with html multihighlighting in php files
> which contains more then 6000 chars...
What problem ?
> - there is a strange behavior with ftp servers - after using
> 1-2 hours the saving, editing.. any operation will be hell
> slow, i did not found the problem source, but i think it is in
> pspad because the same servers work fine with zend editor
Your operating system ?
Posted by: pspad | Date: 2006-03-20 19:11 | IP: IP Logged
If you run compiler, PSPad waits to compiler stops work.
Posted by: ashnur | Date: 2006-03-22 08:48 | IP: IP Logged
thank you again, for your response, i greatly appreciate this.
pspad wrote:
> > php,css,html
> Ctrl+Space
as you may observed i wrote easy solution. after ctrl space i have to type another 5 another chars (c,o,m,m,enter). that's not an easy solution when i want to use it frequently.
> I don't understand
i've tried this a few times:
pspad says in the statusbar Code page: ISO 8859-2
i write: 'őű'. save it. close.when reopen there are only 'ou'.
as i am a hungarian, i frequently use these charachters.
i click on format. it shows ANSI(dunno why? status bar said iso 8859-2.).no prob, i click on iso 8859-2. now both in statusbar and format menu says iso 8859-2.
write 'őű'.save it.close.when open says 'ou'. utf-8 is not an option for me yet.
> What problem ?
this was solved in last build
> in
windows xp professional.
Posted by: Michal Tauš | Date: 2006-03-22 09:47 | IP: IP Logged
22.3.2006 at 9:48, ashnur - Beta forum PSPad wrote:
>> Ctrl+Space
> as you may observed i wrote _easy_ solution. after ctrl space i have to
in HTML is comment first
in PHP you can use CTRL+A on selection instead ctrl+space
Can't confirm. It works fine on my Windows 2000 5.0.2195 SP 4,PSpad 4.5.1.2197
> for me yet.
Charset in menu is used for opened files, too.
If it will be changed to actual file's encoding,
there will be problem in newly opened files.
-mt
Windows 2000 5.0.2195 Service Pack 4
PSpad 4.5.1.2197
Posted by: Futurepower(R) | Date: 2006-03-22 14:01 | IP: IP Logged
Try AutoHotkey to assign your own shortcuts to progam behavior:
Posted by: pspad | Date: 2006-03-23 05:04 | IP: IP Logged
>>> php,css,html
>> Ctrl+Space
Define shrotcut for clip. You can run clip with one shortcut then
>> I don't understand
And Labguage settings in your Windows COntrol panels / Regional settings ?
Is there Hungarian ?
> option for me yet.
Information in the menu format is for new files. Information on the statusbar is for the current file. Rest see previous answer
Posted by: ashnur | Date: 2006-03-27 06:29 | IP: IP Logged
> >> Ctrl+Space
> i have to
> easy solution
dunno, ctrl + a for me is select all
Posted by: ashnur | Date: 2006-03-27 06:42 | IP: IP Logged
> then
how can i do this ? - never mind.. i know how I should do this but it's not a solution but a complication. :( i need my shorcuts, which i use in _all_ other text editors. ok. i understood it's not related to you. but this also remains something i miss from pspad
> 'ou'.
> settings ?
No, there is English and Romanian because i need them there as settings.
anyway, i dont get the point. if someone lives elsewhere then in hungary, or use other regional settings, it is not allowed to use this chars ?
Posted by: pspad | Date: 2006-03-27 08:47 | IP: IP Logged
It's a problem.
Your OS takes English as ANSI. If you open ANSI file, PSPad uses system conversion from the ANSI into UNICODE (in your case conversion from English to Unicode). English doesn't know accented chars.
Posted by: Michal Tauš | Date: 2006-03-27 09:15 | IP: IP Logged
Sorry, it's ctrl+shift+A.
In menu Format - Add/Remove Comment.
-mt
PSpad 4.5.1.2197
