You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2181) English
Posted by: pspad | Date: 2006-02-12 06:38 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2179)
News
Widget keywords support added into TCL/TK highlighter
the HEX editor shows number of selected chars
scripting extended of the project access. New functions: projectSave(), projectFilesCount() and projectFiles(index) - returns file name, projectFileName - returns project file name
new line comment style $ (CPL) in the user highlighter
right bar in the TextDiff allows clicking
Corrections
load KeyMap settings from a file
confirm dialog after close to tray
amtersand char in the fle name and file tab
extended Copy breaks national chars
PHP code explorer and final class
Posted by: Ian | Date: 2006-02-13 00:00 | IP: IP Logged
Some problem with displaying in Lucida Sans Typewriter font. The system, when it finds a hard tab character at the start of the line, displays both the tabbed spaces AND the indenting spaces.
Any editing of the line, is pushed out of line by the number of 'extra' spaces, being twice the number that is should be. Changing the font to another can solves the problem.
This has been happening for a number of versions.
Posted by: Leif Gregory | Date: 2006-02-13 01:00 | IP: IP Logged
I hear you. I've been experiencing this for a number of versions now, but just wasn't sure how to explain what was happening or why. I'm also using Lucida Sans Typewriter. So far, my fix has been to do a Find and Replace with regexp to replace "\t" (a tab) with two spaces. This always fixes it, but now that you've brought up that it appears to be font specific, I'm going to change my fonts now.
Thanks for sussing this out. It was driving me bonkers.
Leif.
Posted by: Ian | Date: 2006-02-13 09:07 | IP: IP Logged
True, changing the font removes the symptom. However, this problem was not in v4.3.3 and only appeared shortly before the formal release of v4.5.0.
And heck, I really like Lucida Sans Typewrites, and Lucida Console is just a bit squishy.
Posted by: vserghi | Date: 2006-02-13 09:40 | IP: IP Logged
I reported this back in November last year, with the latest beta at the time.
Didn't get any response then, and as you've found out, still not fixed yet.
Vas.
Posted by: dgunns | Date: 2006-02-13 20:34 | IP: IP Logged
Still does not highlight brackets in batch files (cmd, bat). This has not worked since going to 4.5.0.
Posted by: gogogadgetscott | Date: 2006-02-13 22:36 | IP: IP Logged
While were on the topic of project access via scripting...
Could we have a function return index of the currently selected item in project?
Can the option to add files to the project root be setup. Currently I open the project file as text and add the item manually.
For example:
New project
-Folder
--File
-Folder2
--File2
-File3
In addition, I would really like to have more command line options, including the following.
- print file
- open file (especially project files, *.ppr) in new instance overriding "Only One Program Instance” setting
Posted by: pspad | Date: 2006-02-14 08:00 | IP: IP Logged
Thank you. Fixed. Available in the next build
Posted by: Replika | Date: 2006-02-14 10:06 | IP: IP Logged
In print-preview, when set font-size to 8 (Courier New), all words are breaked:
i posted:
forum.pspad.com
Post Edited (02-14-2006 11:07)
Posted by: Samuel Plentz | Date: 2006-02-14 12:44 | IP: IP Logged
I found a little bug:
If I am in Hex mode (Insertmode) having nothing selected, the command: Remove marked text in the toolbar is still available.
If I do so nothing happens. If I do so twice nothing happens either, but if I undo the second operation another character is inserted.
