You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2179) English
Posted by: jlczuk | Date: 2006-02-07 13:12 | IP: IP Logged
Egads! Talk about one of the more esoteric settings! Thanks for pointing out for me!
Posted by: Jume | Date: 2006-02-07 21:11 | IP: IP Logged
maybe its time to put that option in a more visible area in a config panel and not in direct edit, since a lot of people report the same thing over and over...
Posted by: displeisisfactap | Date: 2006-02-08 10:31 | IP: IP Logged
Small bug found:
Create new file whith an ampersand (&) in filename.
Open with PSPad and have a look to the name in the tab.
See ya!
Posted by: Replika | Date: 2006-02-09 06:58 | IP: IP Logged
Quote:File is same as your, UTF-8
I don't know, what is different, I have WinXP SP2 without east language support
Excuse me... Did you use Extern Cut & Copy (if no text selected the Cut and Copy functions will work with whole line). I only have problem when use Extern Cut & Copy to quick Cut & Copy current line. If I select some texts and copy, it works fine.
Post Edited (02-09-2006 08:00)
Posted by: Michael S | Date: 2006-02-09 08:08 | IP: IP Logged
Hi there,
a little Bug report:
-Selecting a few lines with different size with block select. (The whole lines)
=>The selected Block jumps around and it looks like the selection couldn't decide what to select
-Selecting a few lines with different size with block select, but not the whole line, only a part in the middle. Then delete the block.
=>Some of the selected chars are not deleted.
e.g.
#define INTERPRETER_OK 0
#define INTERPRETER_INVALID_FILE_HANDLE -1
#define INTERPRETER_ERROR_GET_CB -2
now I try block select between the #define statement and the integer value at the end
" INTERPRETER_OK "
" INTERPRETER_INVALID_FILE_HANDLE "
" INTERPRETER_ERROR_GET_CB "
Then press delete. And the result is that not the whole selected text will be deleted.
It looks like that now:
#define < Alles OK
#define NDLE -1
#define -2
If using Ctrl-Z the Block won't be restored...
Another bug is while printing a few selected lines. (Not in Block mode)
I can not trigger that problem, because sometimes the printing works.
Kind regards
Michael S.
Posted by: Michael S | Date: 2006-02-09 08:15 | IP: IP Logged
Bugreport 2:
In usage with the externeal compiler avr-gcc and arm-gcc the capturing in the logging window hangs up sometimes and I have to restart the whole application, if I want to restart the compiler again.
I've reported that problem a view versions ago but I thought it would be helpful to remind.
OS: WinXP Prof + SP2 (German)
PSPad: 4.5.0 (2179)
Kind regards
Michael S
Posted by: pepperpod | Date: 2006-02-09 10:42 | IP: IP Logged
If I close PSPad (2179) after doing a spellcheck, PSPad crashes. Only happens with 2179. OS WinXP Pro SP2.
Posted by: pspad | Date: 2006-02-09 10:45 | IP: IP Logged
> works fine.
Thank you, it's very important information. I will correct it.
Posted by: Caio | Date: 2006-02-10 13:16 | IP: IP Logged
C syntax highlighter is highlighting C++ keywords such as "interface". That causes variables using these names to be highlighted:
E.g.: "test->interface = interface;" highlights both interface var and interface member;
Posted by: pspad | Date: 2006-02-13 20:36 | IP: IP Logged
Program settings / Editor
activate the [x]Scroll past EOL option
