You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2179) English
Posted by: pspad | Date: 2006-02-05 06:00 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2177)
News
new multiline comment in the user highlighter
goto source in the Text diff works on nonumbered lines too
Corrections
FTP client - year 2005 was placed if a ftp server doesn't return year
missing keywords in the PHP highlighter
Interfaces in the PHP code explorer
ASCII table - char selection
color schemes
and plenty of little bugs...
Jan
Posted by: Replika | Date: 2006-02-05 07:19 | IP: IP Logged
Still bug in Clip & Copy Unicode
forum.pspad.com
forum.pspad.com
Posted by: pspad | Date: 2006-02-05 07:40 | IP: IP Logged
In php file, between php tag, type "jo"(or "join") + Ctrl Space (it shows "join") + Enter. The text ("jo" ) is deleted.
Same error when hold SHIFT and type "JOIN [space]".
Bug in the PHP clip file.
find: [join | Alias for implode]
and add this:
join(|)
under this line
To your copy problem: for me is hard to try, because I can't write in chinnese and I have no east Windows localization
Posted by: Replika | Date: 2006-02-05 10:36 | IP: IP Logged
Quote:To your copy problem: for me is hard to try, because I can't write in chinnese and I have no east Windows localization
I'm Vietnamese . Can you try Vietnamese.zip, copy & paste some lines in this file (utf-8 NO-BOM encoded), and see the error.
I use this tool (Unikey) to type Vietnamese.
Post Edited (02-05-2006 11:39)
Posted by: pspad | Date: 2006-02-05 11:37 | IP: IP Logged
OK. I open your file Profile.PHP
PSPad detect it OK as UTF-8
If I copy some lines contain your national chracters and paste it somewhere in the document, all seems to be OK - chars are same.
Posted by: Replika | Date: 2006-02-05 15:20 | IP: IP Logged
Posted by: pspad | Date: 2006-02-05 15:50 | IP: IP Logged
I beileve you, but here is my Copy/Paste version:
File is same as your, UTF-8
I don't know, what is different, I have WinXP SP2 without east language support
Posted by: Guest | Date: 2006-02-05 22:08 | IP: IP Logged
Just to confirm, I get the same results as you, Jan. It works perfectly fine here (XP SP2, East Asian Support as well).
Posted by: jlczuk | Date: 2006-02-07 11:03 | IP: IP Logged
Thank you for this most wonderful tool!
I do have to report one problem though, that appears to have crept in. I do not know which release this began in. If you edit a file that has 250,000 bytes, the highliting does not occur. If I take one byte away and re-open the file, the hiliting is back.
The 250,000 byte size is the "Size" reported by the file properties, not the "Size on disk" which reports 253,952 bytes.
I am currently using the latest version of PSPad on WinXP.
Posted by: pspad | Date: 2006-02-07 11:25 | IP: IP Logged
Program settings / Direct edit button
HlUptoSize=250000
increase the limit (in Bytes)
