You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2177) English
Posted by: pspad | Date: 2006-01-15 17:55 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
All bugs and requests aren't implemented already, I am at 3 January in my mailbox... Be patinent please...
Question
Some users suggested to use the 7Zip format instead the CAB format for the beta version packages. Do you want to change the beta version package format ?
Changes to 4.5.0 (2175)
News
added support for system folders: %AppData%, %HomePath%, %Temp%, %UserProfile%, %WinDir%
in the backup folder specification you can use all PSPad path related variables
in the Program settings/Program added option [x]Highlight URL addresses
TextDiff function - added band with whole file changes indication
added variable %Project% - the actual project name with the path
in the Program settings added option to set the StatusBar action with the double click instead the single click
Corrections
mouse wheel scroll flickering
change tag char case trim last two chars
line block and bracket completion
TeX highlighter - WordWrap trims TeX commands
sorting in the FTP client
left gutter with and line numbers
'-' char was set as the work break char in the CSS highlighter
'$' char and PL/SQL code explorer
reformat paragraph function
comment block function
Posted by: Joe Belmaati | Date: 2006-01-15 18:14 | IP: IP Logged
pspad wrote:
> Question
No thank you. The current distribution method works just fine.
Sincerely,
Joe Belmaati
Copenhagen Denmark
Posted by: Eemeli | Date: 2006-01-15 18:50 | IP: IP Logged
Same here. No thank you. CAB is good.
Posted by: Vince | Date: 2006-01-15 20:10 | IP: IP Logged
I say .zip and .cab are probably the files most Windows users can open, so use whichever is easiest for you to make and use in your setup program. But if you use 7Zip that's cool too.
Posted by: Leif Gregory | Date: 2006-01-15 23:31 | IP: IP Logged
.CAB files works for me, don't see any reason to change.
Thanks for all the great work with this app. Your efforts are very much appreciated.
Leif.
Posted by: Anonymous User | Date: 2006-01-16 07:11 | IP: IP Logged
Same here. CAB is good.
Posted by: ShiLong | Date: 2006-01-16 08:42 | IP: IP Logged
Bug found in scrolling!
Open an Text file with long paragraphs. Aktivate the word wrap function. The mouse wheel will only scroll to the not wrapped limits of the document, but the wrapped document doesn't reached his end!!
Greetings ShiLong
Posted by: Jon | Date: 2006-01-16 10:12 | IP: IP Logged
Thx Jan for the new beta. You keep to amaze me.
As to 7Z vs CAB: I'd stick with what works.
Posted by: Replika | Date: 2006-01-16 10:53 | IP: IP Logged
I prefer 7zip, it is one of the best Free & Open Source Software with high compression ratio, support both Windows and Linux (but PSPad not run in Linux :( )
Posted by: PsychodelEKS | Date: 2006-01-16 11:29 | IP: IP Logged
Hi, Jan.
Just wonderring if it is possible to use smth like crossed red circle sign icon on the tabs for r/o files? Also it would be nice to have sound notification, when trying to modify such a file (I often type or paste smth in such files and it is always surprising that nothing can be entered ;) ).
This is first version after pspad450b2153, that i started to use (others had a lot of minor bugs), by the way ;) Good work anyway!
Best regards.
