You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2175) English
#21 Re: PSPad 4.5.0 (2175) English
Posted by: pspad | Date: 01/01/2006 09:19 | IP: IP Logged
Did you try Drag/Drop from the code explorer ?
#22 Re: PSPad 4.5.0 (2175) English
Posted by: Lode | Date: 01/01/2006 21:22 | IP: IP Logged
A great new version! I like the dropdown for FTP connections very much smiling smiley
No problems here, only a question. What does this icon stand for?
I changed the display of the [1] myself, but the red icon before the number, I don't know what it means.
#23 Re: PSPad 4.5.0 (2175) English
Posted by: pspad | Date: 01/01/2006 21:47 | IP: IP Logged
This symbol means file from the FTP
#24 Re: PSPad 4.5.0 (2175) English
Posted by: Lode | Date: 01/01/2006 21:49 | IP: IP Logged
Ok, thanks!
#25 Re: PSPad 4.5.0 (2175) English
Posted by: MoMann | Date: 01/02/2006 02:58 | IP: IP Logged
Sorry, for being redundant, I meant to put this mesage on thread.
I am not sure that if all keywords are installed, but I'm using 'incr TCL' extention. The highlighter does work for the majority of the classes keywords words.
Right now it does not support the keyword "common"
also is it possible for code explorer to reflect basic OOP keywords. That will be great.
Thanks,
MoMann
#26 Re: PSPad 4.5.0 (2175) English
Posted by: pspad | Date: 01/02/2006 05:00 | IP: IP Logged
Please. I don't know TCL.
It's useless for me to write me "code explorer reflect basic OOP keywords".
I need some code samples, need a description what should be in the code explorer.
I know, I have your example with the request about the class support in TCL code explorer. I meant it generally for other people.
#27 Re: PSPad 4.5.0 (2175) English
Posted by: ra | Date: 01/02/2006 22:17 | IP: IP Logged
The tab of files from FTP had a white background color in the previous stable release. I'm missing it, now. Can it be configured or got it lost? (This tiny red thing before the file name can't be considered as a replacement IMHO, it's too difficult to make out.)
BTW: Is there a way to do "Save file as" on FTP? Sometimes I'd like to duplicate my current work on the server.
Thank you for all your hard work!
#28 Re: PSPad 4.5.0 (2175) English
Posted by: Lode | Date: 01/02/2006 22:19 | IP: IP Logged
A trick I use now is keep the file open, right click on the file in the FTP manager, change its name. And thén save the open file. Then you have two files.
Post Edited (01-02-2006 23:20)
#29 Re: PSPad 4.5.0 (2175) English
Posted by: Eemeli | Date: 01/03/2006 03:26 | IP: IP Logged
I have one question. How to print big fonts, because if I make some text to big font size and then print, that text is normal size.
#30 Re: PSPad 4.5.0 (2175) English
Posted by: pspad | Date: 01/03/2006 05:36 | IP: IP Logged
File tabs can't be colored due to M$. Win64 doesn't support owner drawing of tabs. And I will not handle different file tabs for the each M$ OS version
