You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2173) beta English
Posted by: pspad | Date: 2005-12-18 18:05 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2164)
News
Program settings / Program-look - you can set format of file tab numbers. If you don't want to have numbered file tabs, set format to %name%
Corrections
mouse wheel in HEX editor
New file with default template content doesn't respect Code Page from the menu Format
Continue comments /** .. */ for C++, PHP
Posted by: denight | Date: 2005-12-19 05:07 | IP: IP Logged
When the 4.5 version will be released? Thanks.
Posted by: pspad | Date: 2005-12-19 06:08 | IP: IP Logged
Up to end of the year. I am waiting for the english help file from the gogogadgetscott
Posted by: pbrico | Date: 2005-12-19 09:38 | IP: IP Logged
Hi Jan,
Thanks for the mouse scrolling in Hexadecimal view. I still have 2 'cosmetic' requests:
1. When trying to scroll outside the limit of a file, the screen is flickering. This doesn't happen in hex mode.
2. In hex mode, viewing a non-unicode file result in a unicode (2 bytes per chars) view.
Thanks for your wonderful work/editor.
Posted by: Michal Tauš | Date: 2005-12-19 09:57 | IP: IP Logged
19.12.2005 at 10:38, pbrico - Beta forum PSPad napsal(a):
> per chars) view.
You have to open file directly in HEX.
If you open file as text and switch to HEX (in menu View)
you can see Unicode.
-mt
Windows 2000 5.0.2195 Service Pack 4
PSpad 4.5.0.2173
Posted by: pspad | Date: 2005-12-19 11:03 | IP: IP Logged
Ad 1) you mean HEX editor or text editor ?
Ad 2) pspad works internally in UNICODE and HEX view is coresponding. If you want to non unicode file view, open it directly in the HEX editor.
Posted by: Maik | Date: 2005-12-19 14:44 | IP: IP Logged
The Problem I reported on 9.12. is still there.
<CITE>
Greetings,
PSPad is a very great Tool, I use it nearly every day.
On my new PC @ work I´ve got a problem.
Every Day, I have to reload my KeyMapping file. PSPad forget it every day. But when I close and reopen PSPad it remembers it.
Do you know what that could be?
</CITE>
Posted by: pbrico | Date: 2005-12-19 15:12 | IP: IP Logged
I mean text editor. In Hex editor, I don't have this behaviour (this is perfect).
OK... That's boring but I will accommodate ...
Posted by: pspad | Date: 2005-12-19 16:35 | IP: IP Logged
Sorry, but I have no other reports from other users with the KeyMap file.
Check if KeyMap.INI isn't set to R/O
Posted by: maxfinity | Date: 2005-12-19 16:41 | IP: IP Logged
I set spelling in "View | Spell Check". After creating one line of text and enter key is pressed, misspelled words are not check on the fly.
Regards,
maxfinity
