You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2164) beta English
Posted by: gogogadgetscott | Date: 2005-12-15 02:33 | IP: IP Logged
In the VBScript sample you demonstrate the new function printFile. What is the Boolean value you pass to it used for?
Posted by: devic | Date: 2005-12-15 04:29 | IP: IP Logged
Posted by: pspad | Date: 2005-12-15 04:34 | IP: IP Logged
printFile(print_dialog: boolean)
Posted by: pspad | Date: 2005-12-15 05:06 | IP: IP Logged
Do you have set Russian in Control panel / Regional settings ?
Posted by: devic | Date: 2005-12-15 05:22 | IP: IP Logged
Thank you Jan!
If I set russian in "Standarts and Formats" under "Regional Options" then is OK!
But it means that currency, date, time will be russian too. It's not good for people who located somewhere else. (like me)
It would be nice to have some option in ini file or registry where I can set my lang.
thanks!
Posted by: pspad | Date: 2005-12-15 05:55 | IP: IP Logged
ANSI works with actual charset, used in Windows.
If you want to mix charsets, you must use sm unicode ready charset - UTF-8, Unicode.
In future version will be code page support extended - CP 1251, ISO...
Posted by: devic | Date: 2005-12-15 06:10 | IP: IP Logged
cool!
yep I know about Unicode, for me was new that "Regional Settings" are important too. Until now I knew that I need change only "Non Unicode language".
Posted by: pspad | Date: 2005-12-15 06:22 | IP: IP Logged
This settings has influences of the system conversion functions ANSI <-> UTF-8 (Unicode)
Posted by: JCurtis | Date: 2005-12-15 11:11 | IP: IP Logged
When I restart PSPad it can't find files that are located on a shared disk.
Posted by: pspad | Date: 2005-12-15 11:39 | IP: IP Logged
Program settings / Files
[x]Store from local drives only
