You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2163) beta English
Goto Page: Previous1 2
#11 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: RickH | Date: 2005-12-12 19:36 | IP: IP Logged
That was it, In the XHTML clip file "img" had %src% instead of %srcp%. Thanks. Sorry to bother.
Rick
#12 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: Replika | Date: 2005-12-13 04:48 | IP: IP Logged
Tiny Bug:
I have a file with a long line:
<?php
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
move cursor to the end of line 3 (aaa...), click to line 2 (or 4), '{' (or '}') still shows in "Line numbers".
Post Edited (12-13-2005 05:48)
#13 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: Replika | Date: 2005-12-13 11:26 | IP: IP Logged
Quote:
When you release next final version.
Hope next final version can be used as a portable application (the program is only compressed, i can manually uncompress and use anywhere) winking smiley
#14 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: pspad | Date: 2005-12-13 11:30 | IP: IP Logged
All releases are published as the Install package and the CAB archive.
You can choose...
#15 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: pbrico | Date: 2005-12-13 16:02 | IP: IP Logged
There is a bug when scrolling with mouse in hexadecimal view. It is possible to scroll beyond the top of the file and lines are overlapping.
#16 Re: PSPad UNICODE 4.5.0 (2163) beta English
Posted by: pbrico | Date: 2005-12-13 16:05 | IP: IP Logged
Doing a "Search/replace" with option "Prompt on each replace" unchecked, works correctly (all occurences are replaced with prompting).
Then doing a "Search/replace" with option "Prompt on each replace" checked, does not prompt anything while replacing occurrences.
