You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2163) beta English
Posted by: pspad | Date: 2005-12-11 15:42 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2161)
News
Search.INI file is obsolete. All settings was moved into Recent.INI file
Corrections
JavaScript comment freezes program
Code Format freezes program
MouseWheel Scroll - correct line scroll
click on the first line in the Code explorer
window switching
Jan
Posted by: Eemeli | Date: 2005-12-11 17:19 | IP: IP Logged
Hey, thanks this new version release. I have only one question today. When you release next final version.
Posted by: pspad | Date: 2005-12-11 18:58 | IP: IP Logged
I am waiting for English help
Posted by: devic | Date: 2005-12-11 21:46 | IP: IP Logged
hello!
HTML Multihighlighter JavaScript
In code explorer window is a tree with functions and variables.
I select A-Z sorted and write some code. Then I decide to refresh the tree and get two bad things
STEP 1. It's refreshed, but I need again to click A-Z sorting, but after 2 step.
STEP 2. For some reason some function or variables block expands and I need close it before I can sort it, otherwise the sorting is inside this group.
thanks!
Posted by: pspad | Date: 2005-12-12 04:54 | IP: IP Logged
For the HTML multihighlighter code explorer is important an actual part of code. This determine a Code exporer type.
Posted by: Nelson | Date: 2005-12-12 07:15 | IP: IP Logged
1. Open a file. Ex: English.ini
2. Click "Text diff with this file" in context menu.
3. Select another file. Ex: ChineseBig5.ini
4. In the "Text diff" tab, Mouse Wheel works strangly.
For example, you can select Line 1 in the "Text diff" tab, and then Mouse Wheel up and down.
Then you'll know what I meant.
Posted by: GuillaumeH | Date: 2005-12-12 15:57 | IP: IP Logged
I have a stupid request. When you move your mouse in the left margin, where the line numbers are, it would be nice if the cursor would mirror itself. Instead of pointing to the left like the regular cursor, it would point to the right.
Posted by: RickH | Date: 2005-12-12 16:34 | IP: IP Logged
In this build, when using the XHTML multihighlighter with the img code clip (ctrl+space) and browsing for the file, the image dimensions and default "alt", etc. are not found/created. The HTML multihighlighter still works fine. This worked in the XHTML multihighlighter in build 2157.
This is a great feature that saves opening up an image editor just to get the image size. I did "customize" the xhtml context file by commenting out a lot of stuff to shorten the list, but I don't think this is the problem.
Great program. It impresses me more every time I use it.
Rick
Posted by: pspad | Date: 2005-12-12 19:02 | IP: IP Logged
And some asset of this behaviour ?
Posted by: pspad | Date: 2005-12-12 19:05 | IP: IP Logged
I try it now with the XHTML multihighlighter and ALT, HEIGHT, WIDTH was created.
Check your clip file XHTML.DEF
