You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2161) beta English
Posted by: pspad | Date: 12/05/2005 16:59 | IP: IP Logged
It's possible,
use arrow next File save button (Ctrl+Alt+S)
Posted by: Skulstad | Date: 12/06/2005 08:50 | IP: IP Logged
Hi. The hour glass isn't showing when pressing Ctrl+Alt+S.
Regards,
Jorn Chr. Skulstad
Posted by: pypardo | Date: 12/07/2005 09:41 | IP: IP Logged
I think I've found a bug related to comments management with this release.
I've got a javascript file with lots of comments.
When I try to add another comment with release 2161 it locks, but works fine with 2092 release.
[b]Procedure:{/b]
1/ I open my javascript file (js extension)
2/ I move my cursor somewhere (but not in a comment)
3/ I type / (/ is displayed on the screen, pspad is not locked)
4/ I type * (* is not displayed, pspad locks)
I think there's something like an infinite loop somewhere when pspad try to find the end of the comment to highlight it.
It locks the same if I first type *, and type / before the *.
Best regards, and thanks for your work.
pierre
Posted by: pspad | Date: 12/07/2005 13:08 | IP: IP Logged
JavaScript freezes bug is fixed. Correction will be available in the next build.
Posted by: pypardo | Date: 12/07/2005 13:49 | IP: IP Logged
Thanks for fast answer, and sorry for previous bold message !!
pierre
pierre
Posted by: ShiLong | Date: 12/08/2005 09:39 | IP: IP Logged
Can you give us a fixed cab file for javascript? the 2157 release feels so old ;)
Posted by: DxGx | Date: 12/08/2005 10:01 | IP: IP Logged
future request:
- sftp support
- auto-hide main panel [small pin like in MS Visual Studio to leave opened or to auto-hide]
- code explorer sort - could it NOT sort all methods like it does now.. i tested on PHP (earlier that's worked and you could choose to sort or not in PSPad configuration now it looks like PSPad ignoring that checkbox in config)
keep this great job
thanks
Posted by: DxGx | Date: 12/08/2005 10:41 | IP: IP Logged
.. and
i have problem with search and replace
for example if i select word that i want to replace, then press CTRL+H, selected word appears in "Find:" field. That's fine... Next i choose "Prompt Each Replace" and when i press OK i get Confirmation message box. There I press "YesToAll" button. Finally search replace result is that i have replaced all words that are lower my selected word AND the words witch are higher of my selected word is NOT replaced including the selected word.
That is not what i want to get when i press "YesToAll" button.
Maybe i doing something wrong? Maybe i need some config line?
thanks again
Posted by: Benz | Date: 12/08/2005 11:07 | IP: IP Logged
I am from Thailand.
My language is Thai.
If you have any free time after fix the important bugs, please you fix how the PsPad read the file in other languages. Right now, PsPad cannot read the thai alphabets and the fonts that shown in the available fonts(Format->Font...) have less fonts than normally.
Thank you
Posted by: gurbao | Date: 12/08/2005 14:14 | IP: IP Logged
using 2161 build, trying to change case (Format - Code Case Change) in a sql file (reserved words) makes my pspad freeze.
Could someone please confirm if this is a bug?
Thanks
