You are here: PSPad forum > Developer forum - new builds > Re: PSPad UNICODE 4.5.0 (2161) beta English
Posted by: Alex | Date: 2005-12-08 14:21 | IP: IP Logged
using 2161 version, opening javascript file makes pspad freeze.
Thanks!
Posted by: pspad | Date: 2005-12-08 17:21 | IP: IP Logged
Your OS ?
Did you uncheck Case sensitive option ?
Did you choose entire scope instead forward direction ? In other case you replace from cursor to the end of the file
Posted by: pspad | Date: 2005-12-08 17:22 | IP: IP Logged
Sorry, I am not Thai, I can't see what you mean, because I can't write in Thai. Can you send me some screenshots ?
Posted by: pspad | Date: 2005-12-08 17:26 | IP: IP Logged
I can confirm it and will correct it.
Posted by: Maik | Date: 2005-12-09 08:40 | IP: IP Logged
Greetings,
PSPad is a very great Tool, I use it nearly every day.
On my new PC @ work I´ve got a problem.
Every Day, I have to reload my KeyMapping file. PSPad forget it every day. But when I close and reopen PSPad it remembers it.
Do you know what that could be?
Maik
Posted by: ShiLong | Date: 2005-12-09 12:35 | IP: IP Logged
i have the same problem! I locked the keymap file, after some frustrations hours. This works fine, but you need to do your settings, save this, lock the file and each time you want do any changes, you must it unlock again.
Greetings,
ShiLong
Posted by: Bart | Date: 2005-12-09 12:54 | IP: IP Logged
the code explorer (and of course pspad itself) is great, but if you have a lot of function, classen, variables... you lost overview of the code explorer.
Unsing thunderbird email client message filer, i get the idea about a filter function with historie for the code explorer.
So that specific types can be filetered, by name (any word) or type
(filter word must be exact same like known type in the code explorer like for Python "Imports", "Functions" or "Lists").
Here is a pic:
