You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2157) beta English
#41 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: mates | Date: 12/01/2005 10:19 | IP: IP Logged
In ASCII table window when accented characters (for ex šđžćč) are typed, the characters are not located in table, for "normal" letters it works.
For example when I want to locate š so I dont have to type it in.
Thanx
#42 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: mates | Date: 12/01/2005 10:21 | IP: IP Logged
š means &_scaron; remove _
#43 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: RickH | Date: 12/01/2005 20:03 | IP: IP Logged
Even with adding some things, I removed enough that everything works great with the clip window now. I've modified the xhtml and css to do exactly what I need (except some browser hacks for IE).
I'm really impressed by how you can rewrite the INI files to make the program work exactly how you need it. Everybody should code this way! Great work!
Rick
#44 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: pspad | Date: 12/01/2005 22:53 | IP: IP Logged
OK
#45 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: pspad | Date: 12/01/2005 22:58 | IP: IP Logged
I can't simulate it.
What I tried:
I open project with files, some files are open
close PSPad
move out folder with files (project file was in different folder)
open PSPad - it opens project without files, but no exception sad smiley
#46 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: ;Op | Date: 12/02/2005 10:51 | IP: IP Logged
I have three problems with the "Search in files" function:
- When I open the "Search in files" dialog, I enter new values in the "Text to find" and "Selected directory" fields, I keep recursive checked as it was, and click "Ok". The search is not processed: it doesn't search at all (I don't see the list of directories processed in the bottom of the dialog, the dialog immediatly closes)
- I then reopen the "Search in files" dialog. The "Text to find" field does not contain the text I just entered, it contains an old value. This is not the expected behavior. The directory is properly set to my last entered value. If I change the text to find and click Ok, then the search if properly processed.
- pressing Cancel button during a Search in Files has no effect
Thanks again Jan smiling smiley
#47 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: stefan.g | Date: 12/02/2005 14:47 | IP: IP Logged
a frustrating bug appeared in this release regarding tabbing - ctrl-tab gets confused and jumps to wrong windows...
here's how you can do it:
ctrl-n (shortcut to open a new file) - pick a text file, or whatever
ctrl-n - open another one
now the focus in on the third and last opened tab. click on the second tab and then on the first one. now ctrl tab should shift between first and second but it moves between third and first.
#48 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: Lolo | Date: 12/03/2005 21:56 | IP: IP Logged
Hi stefan.g,
You should uncheck "Smart File Switching (Ctrl+Tab no sort)" option in Program Behaviour settings.
#49 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: pspad | Date: 12/04/2005 07:21 | IP: IP Logged
> not processed
I havn't this problem or I can't simulate it sad smiley
> properly processed.
There is an word under cursor from the editor, not a last entered value
> effect
Cancel button press is checked after each 10 files. I will decrease it to each 3 files.
#50 Re: PSPad UNICODE 4.5.0 (2157) beta English
Posted by: pspad | Date: 12/04/2005 08:10 | IP: IP Logged
OK. I will add $, %, @ as part of variable in Perl, but I am not able to apply it if only part of line in multihighlighter is written as included script
