You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2157) beta English
Posted by: pspad | Date: 2005-11-28 10:35 | IP: IP Logged
You must choose.
1. you can send only one file as PSPad parameter
2. you can open several files as PSPad parameter
Users want the point 2)
There was a problems with file parameters and I corrected it. Result is that a long file name must be send enclosed by double quotes - M$ standard.
I don't know, why Windows explorer doesn't put double quotes around %1 if you modify file associations in Windows explorer.
Maybe you should ask M$...
Posted by: Ilya | Date: 2005-11-28 11:12 | IP: IP Logged
The point is clear.
Thank you.
Posted by: PsychodelEKS | Date: 2005-11-28 13:54 | IP: IP Logged
I've noticed a wierd "feature" with read-only files, their tabs were greyed out before 2155 and since they are marked with some humdrum sign before filename =(
Will it go on that way, or color'll be returned? Or did I miss smth? I want it back...
Posted by: Nelson | Date: 2005-11-29 01:53 | IP: IP Logged
Hi there, I've found some bugs.
1. I use v4.3.3(2091) and v4.5.0(2157) to open the same file in HEX mode, but they look different. Why ?
2. Use Ctrl+Wheel to decrease Bype_Per_Column to the min. value, then something strange happens. I can't increase it back.
3. Some lines are too long, but the scrollbar doesn't display. So I can't see the end of the lines. I have pressed the "End" key and the caret has moved to the end, but it doesn't display. But if I enable "Word Wrap", I can see the whole line.
Posted by: RickH | Date: 2005-11-29 03:57 | IP: IP Logged
I think I found a bug in the display of the clip file (Ctrl-Space). The full listing is not displayed. Only the first 101 items (through OLli for the default file for XHTML) are shown. The rest cannot be seen, although they are in the file. It's the same for HTML.
Rick
Posted by: pspad | Date: 2005-11-29 05:06 | IP: IP Logged
No, color will not be returned. If you want a different color, ask M$ for correction of the standard TabControl component - on the Win64 doesn't allow owner draw
Posted by: pspad | Date: 2005-11-29 05:15 | IP: IP Logged
And its same in all other clip files.
Did you try write start of template in clip window ?
Posted by: pspad | Date: 2005-11-29 05:21 | IP: IP Logged
You mean open both files directly in HEX mode or swith to HEX mode from text ?
> back.
OK.
Posted by: gogogadgetscott | Date: 2005-11-29 05:38 | IP: IP Logged
I think the new tabs suck. They are wider and the tab number is to large.
I have a 64 bit chip, but do not use Win64. Anyone here using Win64? Why?
Please allow a setting to turn off numbers.
Posted by: pspad | Date: 2005-11-29 05:48 | IP: IP Logged
I think same problems will be on Vista.
