You are here: PSPad forum > Developer forum - new builds > Re: PSPad UNICODE 4.5.0 (2157) beta English
Goto Page: Previous1 2 3 4 5 6
Posted by: Dave | Date: 2005-12-04 18:05 | IP: IP Logged
Jan, Like some other users have suggested here I would like an option to turn off the tab numbers. These new ones make the tabs too wide so that fewer files appear on the screen. Also would it be possible to have Alt 0 to access file number 10?
Post Edited (12-04-2005 19:07)
Dave
Posted by: pspad | Date: 2005-12-04 18:12 | IP: IP Logged
I make some modification, in the last version tab numbers was annoying
I will add option to turn it off
Posted by: Dave | Date: 2005-12-04 20:09 | IP: IP Logged
Thanks Jan
Dave
Posted by: confucius | Date: 2005-12-05 04:21 | IP: IP Logged
Hi, I have logged it at sourceforge.
You can try by downloading this file. Edit it in HTML or multihighlighter color syntax. Move the cursor over the text with the Asian text using the up/down arrow keys.
Text syntax highlighting seems OK.
Posted by: confucius | Date: 2005-12-07 16:53 | IP: IP Logged
Hi. Per sf's support, I got a build of SynEdit from sf (http://mh-nexus.de/downloads/ClearEdit.zip). It works without any problems, even in HTML syntax highlighting. Perhaps they have fixed the problem in their latest build?
Posted by: pspad | Date: 2005-12-07 17:11 | IP: IP Logged
Clear Edit has date 05/2005 and I don't know, what SynEdit version is used. In this program should be used old ansi SYNEDIT version - there are not unicode problems
Posted by: confucius | Date: 2005-12-08 05:44 | IP: IP Logged
Thanks. I look forward to new PSPad versions perhaps with new builds of SynEdit.
