You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2155) beta English
Posted by: rejetto | Date: 2005-11-26 20:10 | IP: IP Logged
the parenthesis matching in PHP has a bug
try this source:
place on the first parenthesis, then use CTRL+M to go to the related one.
the cursor is placed well, i think, but ther INNER parenthesis is highlighted instead of the one i'm moving to.
this is annoying.
Posted by: rejetto | Date: 2005-11-26 20:13 | IP: IP Logged
try this source
$thispageurl = "http://$_SERVER[HTTP_HOST]$_SERVER[SCRIPT_NAME]?$_SERVER[QUERY_STRING]";
select the line with the code, and see how the text is changed.
very weird indeed
Posted by: pspad | Date: 2005-11-26 20:20 | IP: IP Logged
Sorry, I will correct it imediatelly
Posted by: pspad | Date: 2005-11-26 20:22 | IP: IP Logged
And what for is this construction ? Usually is a something inside parenthensis
Posted by: pspad | Date: 2005-11-26 20:25 | IP: IP Logged
I will report it in the Synedit BugTracker. Its problem with painting
Posted by: carbonize | Date: 2005-11-26 22:07 | IP: IP Logged
Sorry if this has been mentioned before but I tried a search with no luck. The tabs of files opened from FTP used to be white but now they are the same colour as tabs for local files.
Carbonize
Posted by: pspad | Date: 2005-11-26 22:17 | IP: IP Logged
I am not able to use OwnerDraw, because M$ doesn't allow it on Win64 and I thing Vista will have same problem.
If you open a file from FTP, it has different symbol on the icon before file name on the file tab.
Posted by: rejetto | Date: 2005-11-27 02:46 | IP: IP Logged
> inside parenthensis
yes, but when i post you examples i remove all that is unnecessary.
i think this should speed up your debugging.
of course i started from a real source. ;)
Posted by: JZarzuela | Date: 2005-11-30 18:13 | IP: IP Logged
Code Explorer, in the case of Java classes, is not working properly. It skips some existing methods (they are not shown in the three).
Thx
---- Example code -----
Code explorer only shown:
m_container
setContainer [green colored]
TestClass() [yellow colored]
I could saw that if you change "protected" to "public" (independently of changing the first "public") the explores shows all the methods.
package none;
* Test class
public abstract class TestClass extends AbstractComponent implements ResponseHandler {
/** The operation container */
private Container m_container;
/** Constructor, crea una nueva instancia de AebResponseHandler */
public AbstractResponseHandlerImpl() {
super();
protected void setContainer(Container aContainer) {
m_container = aContainer;
protected Container getContainer() {
return m_container;
