You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2155) beta English
Posted by: JZarzuela | Date: 2005-11-24 08:40 | IP: IP Logged
Code Explorer, in the case of Java classes, is not working properly. It skips some existing methods (they are not shown in the three).
Thx.
Posted by: pspad | Date: 2005-11-24 08:41 | IP: IP Logged
I need source sample
Posted by: Lolo | Date: 2005-11-24 11:39 | IP: IP Logged
Hi Jan,
It seems that "Log parser debugger" window cannot be translated. I can't see anywhere in language file where to translate it.
Is it possible?
Thanks and have a nice day.
Posted by: Mario Molinari | Date: 2005-11-24 11:46 | IP: IP Logged
Jan,
some time ago, I had notified a problem in the Search-in-Files function. The problem caused the loss of some search parameter between a search and the next one, or even within the same search (i.e., you fill the fields, and then, when pressing Ok, some of them suddenly becomes blank and the search fails), which is quite annoying.
The problem seemed to have misteriously disappeared in beta 2153, but is now back in beta 2155.
Is anyone else experiencing this problem?
For me it is quite a bad thing.
Also, is there a way to disable the Unicode feature altogether? I don't use it, and I wonder whether PSPad performance and stability might be better if this code was disabled.
Thanks anyway for your good work with PSPad!!!
Cheers,
Mario Molinari
Posted by: pspad | Date: 2005-11-24 12:23 | IP: IP Logged
Yes, it has no translation. Debuger is for advanced users only
Posted by: pspad | Date: 2005-11-24 12:26 | IP: IP Logged
I make no changes in FileSearch between 2153 and 2155 versions
Unicode isn't "feature", it's base of the editor. It mean strings manipulation, files manipulation, ... Isn't possible to switch unicode / non unicode by some option
Posted by: Klaus Frank | Date: 2005-11-24 15:48 | IP: IP Logged
Don't think this is a bug.
Right after exctracting this beta, on my system it used a codepage named UTF-16 BE automatically.
To re-enable PSPad displaying standard notepad files, just go to Settings -> Files and Dirs -> Default cp for files opening and make sure that 'ANSI (Windows)' in the dropdown list is selected.
Best regards
Posted by: Mario Molinari | Date: 2005-11-25 08:24 | IP: IP Logged
Jan,
thanks for your quick answer.
> I make no changes in FileSearch between 2153 and 2155 versions.
I'm sure you didn't, still in beta 2153 this feature seems to work better than both in the previous and in the next beta.
Anyway, if it's only my problem, and Search-in-FIles works fine for anyone else, it may be something wrong with my PC or PSPad installation. I don't know what.
Do I need to download something like latest Delphi run-time libraries (my PC is pretty recent, less than one year, Win XP)? Any other idea?
Thanks anyway, ciao,
Mario
Posted by: pspad | Date: 2005-11-25 08:28 | IP: IP Logged
No, PSPad is standalone EXE. You can copy it anywhere and run it.
Posted by: rejetto | Date: 2005-11-26 20:07 | IP: IP Logged
i use black background.
half columns in hex mode are black with seemingly no way to change the color.
result: i got to highlight them to read.
