You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2155) beta English
Posted by: pspad | Date: 2005-11-22 19:41 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2153)
News
New file tabs panel
New option Indent Width (Program settings / Editor) - individual number of chars for the indent/unindent block. It has no influence if real tabs are used
Extended Home/End key splitted to two options
Corrections
TextDiff - missing lines into new file
Senthesize text, cases when '?,' '?:' e.t.c.
Code clips
Insert text to lines if block was select from the end
Jan
Posted by: mdes | Date: 2005-11-22 21:55 | IP: IP Logged
I have a file of 1 KB, which is loaded as empty!
When loaded with notepad, everything is OK.
Same bug with version 2153.
Posted by: pspad | Date: 2005-11-22 21:59 | IP: IP Logged
Without your file I am not able to tell you what's wrong. I gues you have set a bad encoding in the menu format. Set the ANSI code page and press Ctrl+R
Posted by: Lolo | Date: 2005-11-22 23:19 | IP: IP Logged
Hi Jan,
What happened to file numbers on tabs panel?
It is not really important since Alt+number still works.
Thanks for this new release.
Posted by: Thomas | Date: 2005-11-23 08:33 | IP: IP Logged
I like that, thanks. One thing though: the checkbox for the END key does not have a tooltip (the HOME key setting does have one)
Regards
Thomas
Posted by: edex | Date: 2005-11-23 09:25 | IP: IP Logged
Thank you
Can you do the Extended Indent to be applied in HTML Multihighlighter too?
In a file with PHP highligter selected it works fine, but in an (X)HTML multihighlighter file, in <?php...?> doesn't work.
Thank you
Posted by: pierre | Date: 2005-11-23 14:03 | IP: IP Logged
I've got a lot of problem to make a copy (edit/copy menu) in hex editor.
It works some times (but not all the time !!).
Do you think it's possible to add a popup menu in hex edit or to ensure that Ctrl+C (or ctrl+ins) works fine.
Best regards
pierre
Posted by: Martin HS | Date: 2005-11-23 16:19 | IP: IP Logged
Hi Jan,
In "Program-look: Hide file panel" I selected to hide the tab panel, if there is only one file in use. If I start PSPad with a new empty document, or with one document from explorer, the filename is shown nevertheless. After opening a second document and closing it, the name of the first file on the tab panel is hidden in the way I like.
THX for this great software . Best regards Martin
Posted by: asmodai | Date: 2005-11-23 20:38 | IP: IP Logged
Jan,
got 4.3.3 installed, extracted the contents of this cab to the PSPad directory in Program Files.
Now, when I right click / open with / pspad editor a file in a directory as such:
C:\this\is\a\directory with spaces\file.txt
it will open 4 tabs named:
directory, with, spaces, file.txt
and all 4 have NO contents.
given C:\test dir\and again\more deeper\file.txt
I get 4 tabs:
test, and, more, file.txt - again all empty.
If I leave PSPad open and right click / open with / pspad editor then it just opens the file.
It seems you messed up some space handling in the directory path handling?
On the other hand, thanks for the working Unicode support in PSPad now, this was missing for me and I almost was switching away from PSPad since I need to be able to work with Japanese text.
Hope the above feedback helps you.
Posted by: pspad | Date: 2005-11-23 20:51 | IP: IP Logged
Go to program settings / System
Uncheck integration to the right mouse menu, Apply button, check it again OK button.
