You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 2005-11-22 08:28 | IP: IP Logged
Corwin wrote:
> Because i need sometimes an hex editor, who makes no
> conversions to the orginal
> file.
Open your file directly in the HEX editor and don't switch to the HEX mode from text mode
Post Edited (11-22-2005 09:29)
Jan
Posted by: DxGx | Date: 2005-11-22 08:41 | IP: IP Logged
Alex wrote:
> 3s ? ...My laptop is IBM Thinkpad R50e with centrino 1,6 ghz +
> 512 mb...but 1,6mb file is loaded more slowly....
Yep i can nonfirm this
My laptop 1.7GHz, RAM 512 mb. :(
Posted by: Limatho | Date: 2005-11-22 08:51 | IP: IP Logged
In this beta version the "New Menu Style" disappeared from Program Settings | Program Look.
Posted by: stefan.g | Date: 2005-11-22 09:19 | IP: IP Logged
shift + space don't work anymore!
pleeeeeeeeez fix that!
thanks!
Posted by: Corwin | Date: 2005-11-22 09:52 | IP: IP Logged
Hi Jan,
thank you for your solution, this is ok for me.
Ciao,
Corwin
Posted by: pspad | Date: 2005-11-22 09:58 | IP: IP Logged
Because this option has no influence.
Posted by: pspad | Date: 2005-11-22 09:59 | IP: IP Logged
Already fixed, I hope on tonight will be a new build
Posted by: rasferret | Date: 2005-11-23 15:39 | IP: IP Logged
pspad wrote:
> I don't understand.
> If you want remove some highlighter from the highlighter list,
> uncheck the checkbox before highlighter name.
Yes, that's right. But the highlighter is still in the list. If you want to replace it with another one with the same name there will be two entries. Nothing really bad but for me it's a bit bothering.
Posted by: pspad | Date: 2005-11-23 15:56 | IP: IP Logged
Where is in the list ? In Highlighter settings ? There must be.
Posted by: asmodai | Date: 2005-11-23 20:42 | IP: IP Logged
pspad wrote:
> UE has better file handling.
> PSPad must load a whole file into memory first and then display
> it.
Jan,
so how efficient will displaying a 39 MB UTF-8 encoded file be? (And this is not a hypothetical case, this is text I work with.)
Cheers.
