You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
#41 Re: PSPad gutter font
Posted by: Hilbe | Date: 11/21/2005 16:50 | IP: IP Logged
Alex wrote:
> Hi!,
> PSPad is great! smiling smiley ...but can you improve the load time for
> large file?
> With ultraedit...(that's not free...) a 1,6Mb file is loaded in
> a few seconds...
> Thank for the great editor!! winking smiley
I think UltraEdit displays the file as it reads it. Does PSPad wait until the complete file is read before displaying it? Thats how it seems to me. Try opening a large (100 meg+) across the LAN. It'll show you the difference.
#42 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 11/21/2005 17:43 | IP: IP Logged
I don't understand.
If you want remove some highlighter from the highlighter list, uncheck the checkbox before highlighter name.
#43 Re: PSPad gutter font
Posted by: pspad | Date: 11/21/2005 17:45 | IP: IP Logged
UE has better file handling.
PSPad must load a whole file into memory first and then display it.
#44 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 11/21/2005 17:47 | IP: IP Logged
Yes, but not imediatelly.
#45 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Limatho | Date: 11/21/2005 20:56 | IP: IP Logged
I'm not sure how it is in the stable version, but could you also put a checkbox for the active language in the toolbar?
#46 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 11/21/2005 22:25 | IP: IP Logged
It's SpellCheck dictionary select, not PSPad language.
#47 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: carbonize | Date: 11/21/2005 23:13 | IP: IP Logged
bur wrote:
> I have found a small bug.
> Two tags <div> or two tags <li> are at one level, but PSPad
> Code Explorer shows the second tag as enclosed in the first.
> imageimage
> Could You fix it?
> Thanks for a great program.
Did you close the <li> tags as you should when doing valid HTML. Looks to me like because you did not close the <li> tag PSPad just carries on as if all the tags after that are within the list.
Carbonize
#48 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: bur | Date: 11/22/2005 04:17 | IP: IP Logged
Believe me, I close all tags winking smiley
Best regards,
bur
#49 Re: PSPad gutter font
Posted by: Matt | Date: 11/22/2005 05:19 | IP: IP Logged
Glad to see old font back but note that TextDiff line numbers still not reverted grinning smiley
(see point's post)
Just a heads up since i am sure you'll get around to it!
PSPad is rad!!!
#50 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Corwin | Date: 11/22/2005 09:08 | IP: IP Logged
Hi Jan,
thank you for your answer.
Is there any posibility to view a textfile in hex without Unicode transformation ?
When i save a new text file created with your Editor it was not in Unicode.
I need a toggle to switch between normal and unicode-mode for me.
Because i need sometimes an hex editor, who makes no conversions to the orginal
file.
Ciao,
Corwin
