You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
Posted by: ;Op | Date: 2005-11-21 10:58 | IP: IP Logged
Hello Jan
Thanks again for this great new version.
Since the first 4.5 beta, texts with a syntax highlighter including a "bold" attribute (and HTML multi-highlighter) have wider character spacing. This has already been reported (by me, but also by e.g. Pavel Rychetsky on 08-11-2005 12:25 about build 2120). Do you plan to do something about it?
My config : build 2153 on WinXP, FixedSys font
Cheers
Posted by: pspad | Date: 2005-11-21 11:02 | IP: IP Logged
Important is the way how you open this file in the PSPad.
Posted by: pspad | Date: 2005-11-21 11:05 | IP: IP Logged
PSPad works internally in UNICODE. Its reason why 1 char is presented as 2 bytes
Posted by: pspad | Date: 2005-11-21 11:34 | IP: IP Logged
I am not able select a variable include & in the included PHP scripts:
HTML code <?php php code ?> HTML code
Posted by: ShiLong | Date: 2005-11-21 12:04 | IP: IP Logged
SHIFT + SPACE dosn't work know!
Testet in PHP and Multi Highlighter. Build 2153
Greetings,
ShiLong
Posted by: Wacky | Date: 2005-11-21 12:51 | IP: IP Logged
If PSPad is running and i start a new instance of PSPad, than the running PSPad open the new PSPad.exe in Hexmode.
Posted by: Cackos | Date: 2005-11-21 13:43 | IP: IP Logged
I used to work with another text editor, TextPad for many years now, and only recently I was presented to PSPad, and I liked it SO much I changed immediately to this new fantastic editor. However, there are some things I still miss from my old editor.
I sure would like a couple of enhancements:
- PSPad to be able to minimize to the tray (not only close) i.e. Close and Minimize would send to the Tray;
- Our tools selections should be "Saved". I love to work with the clipboard monitor and would like if would stay on for the whole session or even after leaving PSPad and entering again. Currently, each time I enter the application it clears/resets all tool panel tabs. This even happens when I close to the system tray and open again...
thanx and keep on the great work!!!
Cackos
Posted by: pspad | Date: 2005-11-21 13:59 | IP: IP Logged
Problem found
Posted by: rasferret | Date: 2005-11-21 14:36 | IP: IP Logged
thanks for the information... I just missed this menu-item. should drink less coffee...
but I still didn't find a way to remove a highlighter without using another editor. I would appreciate this very much.
Posted by: bur | Date: 2005-11-21 14:53 | IP: IP Logged
I have found a small bug.
Two tags <div> or two tags <li> are at one level, but PSPad Code Explorer shows the second tag as enclosed in the first.
Could You fix it?
Thanks for a great program.
