You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Skulstad | Date: 2005-11-21 07:46 | IP: IP Logged
Hi. It seems like the bad ruler alignment (in my case) relates to Win98SE - it works as usual on Win2k.
Regards
Posted by: rasferret | Date: 2005-11-21 07:50 | IP: IP Logged
great tool... but there are some things I that should be changed or added.
Could you please add an option for editing and removing of highlighters. I added the
highlighter for makefiles but there were some file-endings missing. So I had to edit the
definitionfile. Obviously thats not a problem. But pspad copies the definition into its ini-file. so you have to remove it first in the pspad.ini. but then pspad adds the current settings to the file while ending pspad. so at the next start the highlighter is there again with the old filemask...
so you have to edit pspad.ini with another editor to change it permanently. thats a bit irritating.
It would be best to include an editing/remove-option to pspad. Also you should load the definitions from the ini-files and not store them to pspad.ini.
I haven't tested it yet with this version but the previous one chrashed when I wanted to print without installing a printer before. (I know this sounds a bit stupid but I forgot to install the printer and hadn't thought about it... so it crashed). This should be fixed if it's not already done...
but go on with your great tool. i really like it as a alround-editor.
Posted by: pspad | Date: 2005-11-21 08:55 | IP: IP Logged
> definitionfile.
menu Settings / Highlighter settings if internal highlighter
menu settings / User highlighter if user defined highlighter
> before.
Print preview crashed in previous version.
Posted by: Alex | Date: 2005-11-21 09:45 | IP: IP Logged
3s ? ...My laptop is IBM Thinkpad R50e with centrino 1,6 ghz + 512 mb...but 1,6mb file is loaded more slowly....
Posted by: edex | Date: 2005-11-21 09:50 | IP: IP Logged
Hi
tyzio wrote:
> pspad wrote:
> > See highlighter settings. There are Extended indent chars on
> the second tab
> > Try set char '{' into first edit field
> Yes, it works. Thanks for hint
> But it is possible that when I close the procedure by '}' char,
> this char will be unindent by one?
> example:
> proc rand {} {
> set x 123
> return $x
> and right now, when I put into Extended indent chars '{' and
> '}', I get:
> proc rand {} {
> set x 123
> return $x
> And I need to manually unindent closing bracket.
> Thanks.
I'll be great if pspad will unindent like tyzio said.
I saw that if "Completion of chars ( { [ <..." is enabled it works fine on 'enter' key pressed after '{', but it will be good if it will unindent without that option enabled.
Thank you. I really apreciate your work.
Posted by: pspad | Date: 2005-11-21 09:50 | IP: IP Logged
More details please.
Code explorer is active ?
Code page of your file ?
Posted by: point | Date: 2005-11-21 10:13 | IP: IP Logged
Posted by: Coditor | Date: 2005-11-21 10:16 | IP: IP Logged
Just checking if the double-click to select in PHP and Perl bugs (as reported with previous beta) are still on your radar...
Posted by: pierre | Date: 2005-11-21 10:23 | IP: IP Logged
Hi all,
When I edit one of my file with pspad,
pspad opens 2 tabs.
the file path is
c:\program files\folder\file.ext
PSPAD open a tab
c:\program
and another tab
This functionnality works fine in previous release (not beta).
Maybe something has changed in this area with this new beta 2153
Best regards
pierre
Posted by: Corwin | Date: 2005-11-21 10:44 | IP: IP Logged
i am using the newest beta 4.50 2.1.5.3
when i open a binary like an exe-file, it would be correctly displayed.
but when i open a text-file type "test" and change the view to hex i see something like this:
0000 0001 0002 0003 0004 0005 0006 0007 1 2 3 4 5 6 7
0 FFFE 7400 6500 7300 7400 t e s t
but i am expecting this:
00 01 02 03 04 05 06 07 1 2 3 4 5 6 7
0 74 65 73 74 t e s t
what the reason for this view ? (a bug ?)
Ciao,
Corwin
