You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Matt | Date: 2005-11-19 14:44 | IP: IP Logged
Actually, the line number font was very nice the way it was before. Now it just does not look/feel right.
Is there a way I can change it back without going back to previous build (edit INI file maybe)?
Anyway, why did you change it? Performance considerations?
Posted by: Eemeli | Date: 2005-11-19 15:41 | IP: IP Logged
I like this new version. I don't have founded ugly bugs so far. Thanks Jan.
Posted by: pspad | Date: 2005-11-19 15:42 | IP: IP Logged
OK guys, the old font is back. Download this build again to have it back.
Posted by: drkokr | Date: 2005-11-19 17:52 | IP: IP Logged
valio wrote:
I haven't this problem.
drkokr
- Windows8.1 x64, i5-750, 8GB RAM, PSPad 4.6.0 (2661), dvě ruce a klávesnice, (občas mozek a sem tam hlava)
> have it back.
Thank you, Jan, for your quick modification of font for the line numbers.
drkokr
Posted by: edex | Date: 2005-11-20 19:32 | IP: IP Logged
hi
pspad is great, and I have 2 requests:
1. I often used the double-click word select and then, with the left mouse button pressed, select more words. can you do that?
2. can you expand the "Extended HOME / END key" option for HOME and END keys separate
thank you and excuse my bad english
Posted by: pspad | Date: 2005-11-20 19:46 | IP: IP Logged
DblClick to select word
Shift+Click to select end of the block word
Added into ToDo
Posted by: Alex | Date: 2005-11-20 22:11 | IP: IP Logged
Hi!,
PSPad is great! ...but can you improve the load time for large file?
With ultraedit...(that's not free...) a 1,6Mb file is loaded in a few seconds...
Thank for the great editor!!
Posted by: pspad | Date: 2005-11-21 05:51 | IP: IP Logged
Your computer configuration ?
I load about 10MB file + PSPad start up to 3s
Posted by: Jarmo | Date: 2005-11-21 06:21 | IP: IP Logged
Running notepad replacement without any parameters opens pspad.exe in PSPad. Same happens when you already has PSPad open and run PSPad second time without parameters; it opens itself in editor.
