You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2153) beta English
Goto Page: 1 2 3 4 5 6 7 Next
#1 PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 2005-11-18 21:01 | IP: IP Logged
Download link: pspad.cincura.net (1.7 MB)
Changes to 4.5.0 (2140)
News
clip files handling was rewrited
internal HTML preview refresh after save file if visible
user highlighters - new vcomment style " ". Only used comment styles are stored in definition
Expression evaluator allow you paste the result only or an expression with the result
in SpellCheck settings you can switch On/Off autocorrection
File setting stores the Right edge position too
User convertors - the backward conversion takes replace list from the end
single click in the project tree activates a file if open
Corrections
exception after close internal HTML preview with JavaScript
Autocorrection in HTML - problem with HTML elements
missing ecNextLineStart editor command
Autorefresh Window setting from the menu Window
Hex editor colors doesn't coresponds to the program settings
select string inside brackets
select string inside quotes with mouse
MSDos BAT highlighter and ECHO followed by a command highlighting
Autocomplete function doesn't offer keywords from the user highlighter definition if no word was found in the text
TextDiff - the result position depends of result setting from the Program settings / Editor
missing Editor shortcuts (I hope its a final corretion)
problems if PSPad was running and file contains '.exe' in the middle of the file name
nonsence string was stored in the Project settings / Web server if empty
user highlighter - some chars (e.g. ':') wasn't highlighted as a symbol
Clipboard monitor pastes text with the line break
CSS highlighting
Jan
#2 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Jume | Date: 2005-11-19 06:53 | IP: IP Logged
mmm, what happened to the font of the line numbers?
#3 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 2005-11-19 08:02 | IP: IP Logged
It's worst ?
#4 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: sproutworks | Date: 2005-11-19 10:15 | IP: IP Logged
It looks like the line numbers are using a bitmapped font that is being scaled so it looks pixelated.
SproutWorks Software Design
#5 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Jume | Date: 2005-11-19 10:42 | IP: IP Logged
a image is worth 1000 words
before: www.konithuki.com
now: www.konithuki.com
#6 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: PsychodelEKS | Date: 2005-11-19 11:30 | IP: IP Logged
Previous variant was better... BTW numbers seem to be smaller now and harder to read (1600x1200). But still, PSPad is the best winking smiley
#7 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 2005-11-19 11:31 | IP: IP Logged
Gutter uses Terminal font if exists
#8 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: Skulstad | Date: 2005-11-19 12:47 | IP: IP Logged
The ruler is bad aligned
#9 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: pspad | Date: 2005-11-19 12:50 | IP: IP Logged
Screen shot please
#10 Re: PSPad UNICODE 4.5.0 (2153) beta English
Posted by: valio | Date: 2005-11-19 14:42 | IP: IP Logged
--- valio
