You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2140) beta English
Goto Page: Previous1 2 3 4 5 6 7
Posted by: pspad | Date: 2005-11-17 15:56 | IP: IP Logged
Next beta will come up to the end of this week and full version I want publish this month end.
Posted by: pspad | Date: 2005-11-17 17:32 | IP: IP Logged
I tested it.
I made file with numbers on lines ( 1..20 ) to easy localize problems
I save file, delete lines with numbers 4,7,10
I call Compare with disk content and then I call the Missing lines into new file function.
In new editor window I saw lines with numbers 4,7,10
I don't see any problem
Posted by: Lorenzo | Date: 2005-11-18 13:36 | IP: IP Logged
I just noticed a problem with the Code Explorer and ".c" files.
Basically, when there's a "}" in a char or in a string,
it is interpreted as a closing-block parenthesis.
Reproducing file.c:
void main()
test1(2);
void test1(int a)
char s;
s = '}';
if (a > 0) {
printf("Hi");
void test2(int b)
char c;
c = '}';
if (b > 0) {
printf("Hi");
The Code Explorer window looks like:
[-] Function
|-- main()
|-- test1(int a)
|-- if (a > 0)
|-- test2(int b)
|-- if (b > 0)
clearly, there are two bogus entries:
-- if(a > 0)
and
-- if(b > 0)
Can you have a look?
Thanks
