You are here: PSPad forum > Developer forum - new builds > PSPad UNICODE 4.5.0 (2140) beta English
Posted by: Naughty Muppet | Date: 2005-11-15 07:01 | IP: IP Logged
I can also confirm that the print preview doesn´t crash with syntax highlighting off.
Posted by: rio | Date: 2005-11-15 07:34 | IP: IP Logged
just add this to stop receiving this thread again by mail.
Posted by: rino | Date: 2005-11-15 11:25 | IP: IP Logged
Hallo,
Sorry, my english is not as good as pspad.
There is a bug in comparing files, that is quite older.
When comparing a file in pspad with another file, I get a new tab with both files listed and all differing lines marked with different colors. That works fine.
When I work with the results I get a new tab called "Differences only", where only the differing lines are listet. But these listet lines are wrong. It is always listed one line before the differing line.
Please can you fix it?
Thank you
rino
Posted by: Coditor | Date: 2005-11-15 13:22 | IP: IP Logged
Tnx for the tip wrt "Smart chars completion" Fixed it for me.
There is another bug that I mentioned earlier:
<?php
$name = "John";
<b>Hello <?= $name ?>,</b><br />
If you double-click $name in the first instance, it'll include the $ in the selection, if you try the same for the second instance (where you echo the name) it doesn't include the $.
Today I have found that in Perl it never includes the $ (or % or @) when double-clicking variable names.
Posted by: Lolo | Date: 2005-11-15 13:53 | IP: IP Logged
I have a small but annoying bug.
If PSPad is already launched and you try to open a file from a folder with spaces inside (like "test files") and with name like "myfile.exe.xxx" (xxx is what you want) PSPad only open empty files named "test" (with "X:\test" in title bar) and "myfile.exe.xxx" (with "files\myfile.exe.xxx" in title bar)
Could you correct that.
Thanks and have a nice day.
Posted by: rio | Date: 2005-11-15 15:32 | IP: IP Logged
guys, how to unsubscribe this topic? pls help.
Posted by: Stefan | Date: 2005-11-15 16:31 | IP: IP Logged
Hi rio
log in into PSPad forum, go to your profile and edit your preferences.
Posted by: rio | Date: 2005-11-15 17:30 | IP: IP Logged
Thx all, I've removed it.
Posted by: pspad | Date: 2005-11-15 17:45 | IP: IP Logged
Yes, thank you for the info
Posted by: Wacky | Date: 2005-11-17 13:37 | IP: IP Logged
When will the next beta come and when will the next final come?
